I've come across a few interesting differences in BP motors (some of which are fairly well-known):
i took the crank out of a 94 Escort GT at the junkyard yesterday and guess what?? no MBSP. everything else was the same: oil pan, oil squirters (1st time seeing them up close - pretty cool ) and the main bearing caps even had the bolt holes for the MBSP. Jess with a 95 turbo GT also posted on the miataforum that his BP didn't have a MBSP.....
the reason for wanting the crank was 1) to see if it was a big-nose and 2) i wondered if it was forged. not sure yet on the big-nose part but it definitely appears to be forged (based on the *wide* 'seam' that is noticeable running along the crank). the thing was HEAVY too - man it almost seems like its half of the short block's weight!!
i have a 91 Escort GT long block that i will soon be tearing apart. it'll be interesting to see 1) if the crank is forged and 2) if it has a MBSP. my guess/hope is yes on both counts....
there is definitely some confusion out there - as i've read on the miataforum that the official word from mazda is that ALL BP 1.8 cranks are forged. the 'mazda answer', though, may have just related to the *miata* BP.....
2 members over there have stated that they've seen Escort GT cranks that are (apparently) *cast*. another very reputable member has stated that all BP DOHC motors had forged cranks - including Mazda, Ford, and Kia. he said the ONLY *cast* BP crank came in the SOHC motor of the 90-4 Protege DX
on another note, a guy on protegeclub recently installed the *factory header* on his 1st gen pro. he talked to his local mazda dealer and they told him that the factory header was put only on the automatic-equipped '94 (of course all 2nd gen BP's have it).
at this same junkyard yesterday, i came across a 94 5spd LX with a 10/93 build date. it had the factory header.....
never believe what you hear from the dealer
i'll post some other stuff later.
if anyone else with a BP powered FWD car (including Kia) wants to post their findings, i'd be interested.
