i thought there was a writeup on here about this i cant find it if you guys could get back to me with quick responses itd be nice as im trying to head out to a meet tonight and id like to drive my egt there, but the ****ing shifter fell through this morning so im trying to figure out how to fix it
fixing dropped shifter?
yea, go to the yard, find a regular escort and swap the stabilizer bar onto your shift bar and put it back in.... oh and fill it with jb weld so it doesnt happen to the next one.... or the easy way w/o buying anything but jb weld, is to just sand the inside where the bushing fell from down, get the 3 minute jb fill it pull it back up and let it dry, then fil the top and bottom again after, i think i used 2 or 3 of the small cheap packs.....92 protege lx-
94 protege lx-
I have the shift support bar business from my 95 i could sell it to yaEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Z shaped bracket from the underside makes my shifter happy. I also filled the gap where the old bushings were with window weld to keep the vibration down"Discontent is the first necessity of progress."
its on my home computer, ill post it tonight"Discontent is the first necessity of progress."
Originally posted by Pox View PostAny pics of your solutions?
I went the more "direct" method of re-attaching with the crappy arc welder.
When I install my G-series, I'll have less ugly linkage.I peered out from the castle window and looked over the splendor of ROTM county. Yes, twas' a much simpler time back then. Peasants would go about their postings, and I, the mod, would rule over them with an iron fist.
i dont know why there are such elaborate repairs on this ... the issue is the rubber bond breaks between the shifter pivot housing and the locating arm .. ( i stole sock's pic to illustrate )
just clean it out .. push the pivot back into the housing and sink a couple screws one on each side into the rubber BUT NOT THE PIVOT ... 1/2" or less long self tapping screws ftw
i fixed it today, i just made a hole and stuck a bolt and a nut lol and it did the trick real well. havent thought about putting window weld in there yet but i might. i got other things to worry about right now, my ****ing car rolled down my lift and hit another car but there really isnt much dammage butthe ****icking lock is broken cuz the door doesn't close it just bounces back cuz i think the lock is in the close position
Originally posted by deathtrigga View Posti fixed it today, i just made a hole and stuck a bolt and a nut lol and it did the trick real well. havent thought about putting window weld in there yet but i might. i got other things to worry about right now, my ****ing car rolled down my lift and hit another car but there really isnt much dammage butthe ****icking lock is broken cuz the door doesn't close it just bounces back cuz i think the lock is in the close position
I did that and the nut eventually comes out cause of the vibration.
Weld the nut in place, even 1 tac weld will do it.
i had the screw threw the rubber fail on me when the inside of the busing broke off too, so then I welded nuts to it, the screws stripped out! so then i moved onto the newer solution
old way (last 2 years)
new way (has no imediate stresses and is very simple (KISS!)
