GTX ECU pin outs & other useful stuff
    just figured this could help people out who are doing swaps.
    That's some great info there.
    I'm going to add links to the PDF shop manuals that I have also, as the more info is available, the easier things become for everyone. Delete them if you want, no big deal. They are probably copyright-infringed, since the actual shop manuals cost a ton of money.
    Edited for copyright safety.
    speak to sarge if you desire links.
    --sarge
      not deleteing anything like you said the more info the better.
        The more info the better, but we could get ****ed for posting this ****. I say delete it, as we've discussed this before and that was the consensus.
        '91 LX
        '03 Mazdaspeed Protege #235
        Originally posted by pigeon
          well thats that, talk to sarge if you want PDF shop manual links.
            Works for me. I'd rather not get the site into trouble, because then we're all up poop creek when it comes to learning things.
            If you want/need the links, send me a PM. I've also got a thread over on a certain Escort Owners forum that has the same links.
            --sarge
              I think this might be useful.
              BP-05 Turbo-Sold
              2004 MK4 AWP Jetta GLI
                Some other info our good friend yesidoeatpie posted in his infini thread:
                Originally posted by yesidoeatpie
                That should help get you up to speed.... it bolts onto the side of the air flow meter
                This one relates to his cutting out at 5000 rpm issue, and how he fixed it.
                  these diagrams are extremely usefull, Thanks for posting them, deff helping me with my swap , Keep it up for the people who need to do our homework on a budget, thanks again guys!!!!
                  I GOT 10 on IT, zoom zoom!
                    Does anyone have the actual wiring diagrams for the gtx engine control and not just the pinouts? I am using an EGT auto harness and am going to run a gtx ecu. I need those to make sure what mazda calls things matches up with what my ford EVTM is calling them.
                      considering the year variations its difficult to assume anything relative with the wiring harness's. tracing back what your unsure of will be your best answer.
                      using the ECU pinouts you can figure all of your underdash woes in an hours time or less.
                      PS. most of the auto EGT wires to the black plug are not used
                        Hi, I'm doing a gtx bpt into a bh and I need to sort out some plug differences under the dash
                          your best bet is to physically compare harness's while studying the FSM wiring diagrams for each.
