I read somewhere on here that you can swap the head off of a 1.5l miata onto the Z5. what my plan is to swap the head off of a miata (after have the ports polished 5 angle valve job and slightly more agressive cam) on to the bottom end of my z5 and turbo it cause i know for a fact that there is a million and a half different kits to turbo the miata.. just lookin for any thoughts and concerns before i dive head first into this project
Miata Head Conversion/Turbo
Im not sure but Ill take your miata with the z5 when youre done.http://www.cardomain.com/id/stamar
:microwave
why would a turbo kit designed for a rwd car fit a fwd?
you just have to diy.
start from scratch, almost everything will be custom.Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms sideskirts... check
ms rear skirts... check
ms spoiler... check
ms struts... check
Still trying for a bp swap..:
um the protege had a b6. and theres turbos for it.
If the miata had the same b6, well its compatible.
My whole key point though, is Id much rather have the miata. with the z5. that sounds much cooler.
lol. I mean if youre makin a gen 2 protege from a gen 1 miata... Id rather have the other way around.
I mean check it out, z5 is lighter, has more hp better gas mileage. dohc. kicks all ass. That would be a cool vehicle.http://www.cardomain.com/id/stamar
:microwave
Yeah, the Protege had a B6 in the 1st gen, but the Miata still had no 1.5L...anyways, maybe that was a typo.
But a B6 head wouldn't fit on a Z5, and since we're in the 2nd gen forum and no 2nd gen had a B6, it's a moot point anyways.
Also, regarding the Miata's B6:
B6ZE(RS)
1.6 L B6ZE(RS) - 1597 cc (78x83.6 mm) - Developed for the Mazda Miata (1989-93). The engine uses a DOHC 16-valve alloy head with a lightened crankshaft and flywheel to allow a 7200 rpm redline. An aluminum sump with cooling fins is an unusual featue of this engine. The Japanese version of the engine had a 9.4:1 compression ratio and produced 120 hp (90 kW) and 100 ft·lbf (136 N·m).
The 323 GTX's B6T is the most powerful B6 engine of all at 147hp
Originally posted by firelizardYeah, the Protege had a B6 in the 1st gen, but the Miata still had no 1.5L...anyways, maybe that was a typo.
It's a much more powerful engine than the Z5. It's other B6s that are weak, such as in the 1st Gen Protege
whats most different is the exhaust port. plenty of pictures of it right here in the forum
this guy is correct most of you responding are wrong.http://www.cardomain.com/id/stamar
:microwave
this guy is correct most of you responding are wrong.Almost there
jdm tails... check
jdm bumper... check
ms lip... check
ms grill... check
ms spoiler... check
ms struts... check
i was thinkin i could use the manifold from the 1.6 (yes the 1.5 was a typo) cause i think they collect in the middle. i realise i would have to custom fab a downpipe. i was jsut wondering what the clearence problems would be with the radiator. but a little fab work im ok with cause i want to dump some of my deployment money under the hood of this car and try to make it as much of a sleeper as i can.. i realise it would prob be easier to just swap the BP in it but i HATE wiring. God i miss my nova a small block with nothing electrical on it (save a few sensors) but anyways....Originally posted by 95progecko?
don't you mean GEICO?
Well, there appears to be barely any room from the exhaust manifold to the rad stuff...maybe..but that's with the shield on too.
I reckon if the exhaust manifold doesn't take too much room and it's the sort with the turbo below it, there shouldn't be any clearance issues that I can think of...with the intake out of the way there should be a good amount of space, at least on the driver's side. If I recall, though, it's pretty cramped on the passenger side, where all the belts are.
Here's a high res picture:
This thread might just bring my motivation back to working on the z5. I had just about gave up on doing any more modding on the 1.5 engine due to lack of mods. Heck my 1.9 sohc ford escort has more mods available for a long shot and there really isn't that much.97 protege dx few mods
94 escort lx heavily modded
