Loose Shifter
    Loose Shifter
    What causes my shifter to have alot of slop in it. I replaced the shifter rod bushings ( the ones that are in the knuckel right before the trannie) and they helped a little, but it still has alot of slop.
    Roads? Where we are going we don't need roads...
    try replacing the other bushings? theres the ones in the shifter and also the shifter support rod bushing
      I saw the one on the support rod and it looked ok (although I may just change it anyway) - how do you get to the one on the shifter? Is it on the bottom side?
        yes its at the bottom pivot point where the shifter connects to the shift rod. energy suspension sells a polyurethane support rod bushing thats probably as cheap or cheaper than an OEM one. suspension.com has it under the escort ZX2
          Also look in the for sale section under group buys. 1 of our local people sells good quality bushing for the whole assembly. Maz1.8t I believe is his screen name. Send him a pm and se if he has some. I need a set myself soon.
            Oh do they? Son of a bitch. I made one out of a bushing I bought at the hardware store. I think it cost me 3 bucks total, but for the irritation of sizing it to fit I probably would have been happier just getting the ES poly one.
            Clint
            1994 Mazda Protege DX (261Kmiles): Eibach springs, Tokico struts, Addco sway bars, massively ghetto-fabulous OBX camber bolts set to max. -ve, Energy Suspension LCA bushings, disc brake conversion, Carbotech XP8 (front) and AX6 (rear) pads, ATE Superblue, 15x7 Kazera KZ-M w/ 205/50/15 Avon Tech Ra (track), 15x6 Miata wheels w/ 195/50/15 Hankook Ventus R-S2 (street) and 14" stock wheels w/ Blizzak WS-60 (ice racing), A/C delete, BP swap, POS Pacesetter (w/ leak), 2.25" custom exhaust, cage and full SCCA ITA prep possibly in the works...
            1995 3000GT VR-4:Tein Flex, 332mm Stoptechs, manual steering conversion, custom brake lines with cockpit-mounted prop. valve, AWS delete, DSM sidemounts, full ATR single-exit, 13g/9b mismatch w/9psi WG springs, DN o2 housings, SAFC, AEM wideband, much more, etc.
            1987 BMW 325is:Bilsteins/H&R Springs, very solid motor mounts, 220k - stodgy daily driver
              Hey man, I went to that site and was unable to find the parts that I was looking for. I was after the shifter rod support bushing and it was only avail. for the 97-01. I think that I have read that its compatable but I'm not sure. Someone help me out
                heard nothing but good about the nyloil bushings he was/is making ... and he sells em seperately or in kits
                found the link http://www.wihandyman.com/forum/showthread.php?t=24152
                  i have corksport bronzoil bushings on the shifter. . . theyre worth every penny.
                    Not to be pretentious but mines are cheaper, lighter and won't corrode cause they aren't steel.
                    But I once had the bronzoils, great product!
