Old Busted!
New Hotness!
This ONLY applies 4 stud BG or BA models, GTR/GTX BG unknown, BA V6 will need some playing with different rotor sizes
So far i have found two options for this upgrade
one requires cutting of stuff
the other is bolt on
first the parts for option 1 ( No cutting of stuff)
BA V6 hubs complete
BG 4 cly 4 stud wheel bearings and 4 stud centers x 2
Rotors; Your choice of either Slotted/drilled BG GTX/ Astina GT rotors or NB8 MX5/Miata rotors (270mm), * Pads overlap 1mm when using stock 257mm rotors
Calipers; BJ series wagon Subaru Legacy GT turbo (2pot)
Brake brackets; Mazda GD 626/TX5/Probe
Washers of 2-3mm , Cyl head bolt washers work well (i'll explain later)
Brake pads; as above, but use some Bendix DB1114 or something better than OEM
Brake lines; your choice of either OEM/Braided etc for BG models * Careful, there are two types ive found, a large and a small Neck Banjo head, i tested using the a split small neck type, all ok, but my car was fitted with a large neck banjo bolt. Large neck requires filling down part of the caliper, 5 mins extra
First Push out the V6 5 stud Center, push in the 4 stud center
Paint/bling up the calipers from the Subi/Mazda combo
Take note of the numbers on the caliper " AD602T " this may have changed during the Subi models, but you need the one with 1 bolt , not 2
the orange brings out the color in my eyes
, best of all NO cutting
, just bolt it to the V6 hubs, put 2-3mm thick washers between HUb and caliper to be on the safe side, ie DONT TEST FIT using 21mm Rotors when you have 22mm, kinda confuses you when you see 4mm clear on side yet only 1.5 on the other
removal of old setup from ya car,
Fit new rotors, , put the good heat/copper grease on moving parts and bolt together with new pads
check steering arm lengths are ok, bleed them brakes, run/ bed pads in ,, DONE
Option two (cutting, swearing, beer/bourbons, & time) <-- i No longer recommend this unless you enjoy trial and error.. **** IT
Parts for Option 2
BA V6 hubs complete
Calipers; T series Mazda Millenia/Xedos 9 S/C or 2.5 V6 (2pot)
Brake brackets; As above
Brake pads; as above, but use some Bendix DB1326 or something better than OEM
Brake lines; your choice of either OEM or Braided etc for BG models *work fine with either small or big neck banjo heads
Take note of the caliper cast numbers "AD43T" and 2 bolt arrangement
You need to cut back this much off the caliper bracket, tiny amounts off the hubs, casting line was in my way on 1 hub, other was ok
* The bracket side facing the Wheels needs to be "trimmed" if it hits your wheels...my 14" OEM mazda mags clear it..yet my Enkai stuff hits the bracket, needs a good 2-3mm trimmed off it ...<--reason i gave up for the night
The bolt holes in the V6 hub needs to be drilled out 2mm to fit the millenia bolts, 14mm i think? i didnt do that bit
the dust sheild? also needs a tiny amount chopped off, 2mm as it hits the corner of the bracket
Strangely but there is NO overlap on the Millenia pad when using stock Astina GT rotors???
Passes the 14" wheel test, i started to laugh when this fitted
drop new pads in
Fit new rotors, and bolt together
removal of old setup from ya car, Bolt in the above setup, check steering arm lengths are ok, bleed them brakes, run/ bed pads in ,, DONE[/b]
New Hotness!
BA V6 hubs complete
Parts for Option 2
BA V6 hubs complete
drop new pads in
