so someone on FEOA made a pretty sweet find.... should work for 92.5-94 protege spindles (or 3rd gen escort spindles) with the larger diameter ball joints:
http://www.feoa.net/modules.php?name...414&highlight=
I discovered something while researching for another project at the junkyard today. A 2nd Gen RX7 lower ball joint will bolt up to a BG lower control arm. The ball joint only fits the 3rd gen escort spindle unfortunatly, sorry 2nd gens. The ball joint end is 17.9mm for a 2nd gen RX7, 2nd gen Probe/MX6, and a 3rd gen escort. The 2nd gen escort is 15.9mm. The advantage to all this is the RX7 ball joint is longer by a 1/2" or 12.7mm (approx) there by increasing front track and negative camber, plus as an added bonus it is aluminum and lighter weight.
