Did some experiments on a Dynojet @ sea-level. Temp was mid 70's, engine had 223,440 miles, new spark plugs/wires, 87 octane, and the mods (minus the 2nd gen DC) listed in my sig.
Basically i wanted to compare the 1st gen and 2nd gen upper intake manifold - or Dynamic Chamber, DC for short. The 2nd gen DC is 1" taller, giving it a correspondingly larger volume than the 1st gen DC. I expected it to produce gains comparable to the header, but.... NEVER trust your butt dyno
First i wanted to get some baselines on the Dynojet with the stock 1st gen DC:
1st run - 16 degree timing:
---- 113.1 hp/108.0 ftlbs ----
nice, smooth power from 3000rpm-4200; then VERY choppy untill 6400-7000, where it went smooth again
2nd run - 14 degree timing:
---- 115 hp/107.4 ftlbs ----
overall good-looking run
3rd run - 11 degree timing:
---- 113 hp/103.8 ftlbs ----
Next, i put it back to ~14 degrees timing, and then tuned the RX7 some but didn't really do any better than with the setting i went in with. So... i put the stock VAF on.
9th run - stock VAF(no filter):
---- 114.7 hp/108.9 ftlbs ----
virtually no loss in hp compared to the RX7 VAF but nearly 2ftlbs better torque - and the engine was thoroughly heat-soaked by then! the little difference in peak hp between the 2 VAF's was especially a surprise.
Next i let the engine cool so as to be able to put on a *modified* 2nd gen DC. Besides making the stock throttle body fit, the experimental modification involved removing the divider/ridge that separates the high rpm chamber from the main chamber. This divider is present in both DC's. A friend cut ~1" of it away using a rotary file.
Modified 2nd gen DC results:
10th run - with stock VAF(no filter):
---- 112.9 hp/107.2 ftlbs ----
surprise surprise! less hp and torque than the stock DC! (with the stock VAF....)
the air/fuel readings showed it running richer.....
however the RX7 VAF improved things
12th run - w/RX7 VAF(no filter):
---- 114.8 hp/108.5 ftlbs ----
good hp and nice torque
did a little tuning of the RX7 VAF with only minor changes.
next we made some cam changes with adjustable cam gears.
15th run - advanced intake cam 2 degrees:
---- 116 hp/108.5 ftlbs ----
16th run - retarded exhaust cam 1 degree with intake cam still advanced:
---- 115 hp/108.9 ftlbs ----
17th run - exhaust cam back to stock, intake cam retarded 2 degrees:
---- 113.8 hp/106.2 ftlbs ----
18th run - intake cam retarded 4 degrees:
---- 116.1 hp/108.7 ftlbs ----
strong hp and torque
19th final run - intake cam advanced 4 degrees:
again nice hp and torque
gotta go for now, i'll summarize some things later
