Yes since I don't have one and I assume it would be difficult to find the OEM part..Where is the best place to splice into the power source now that the harness is opened up?
WilyB's 93 GT rebuild
New Thread:
Old Threads:
i see VERY few differences between the BP/FE3. the FE3 is wired similar to a miata per instance.
the BP harness should be a top notch canidate in order to build/re wire to the FE3---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
4 wire VS 3 wire is merely an additional ground... grab a 3 wire O2 sensor from a z5 engine (2nd gen protege)---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Not of late... I've had to do some work on the BJ, then I bought a 91 GT as a winter car... been working on that one...Hoping to have it pass safety so I can get on with the FE3. I didn't get to drive the car this summer and I'll be damned if I go without it a second summer...
I should be back to it in a few weeks91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
Wow nothing since December...been lazy...
Actually no... I've been playing with the FE3 wiring harness, and since I can't pin down the correct OEM IATS and or AFM, and can't get around the Canadian "Meter" relay issue, I've decided to go with a standalone system.
So as I pull the engine out of it again to paint the engine bay, I'm scanning the rear section of the car to find some pretty bad corrosion that will definitely need some immediate attention...This is bad stuff too... real hidden...horrible...
So I think I'll take care of that and also replace the corroded strut tower caps...
Pics soon...91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
phil. i can send you a cad file of a strut tower over lay plate you can mig right overtop of the exisiting/ or shall i say not so existing strut tower...---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
New Thread:
Old Threads:
New Thread:
Old Threads:
Yeah, rear deck is problematic. I had to deal with it when I practiced on the donor. After having drilled out some welds on each end I still needed screw jacks to bend it up. A lot of metal meets up there...This time I'll drill out a few more welds towards the rear window, loosen it up a bit more.91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
So here is what I discovered, which ultimately pushed my finish date out a tad... I'm not going to put more power into something that can't hold it...so it's back to sandblasting, cutting and welding... However, this is the last of the corrosion...once this and the strut towers are done, it will be time to re-assemble...
Lots of work ahead; I'll need to rebuild the brackets for the trailing arms, rebuild that floor support, cut out and rebuild the inside rocker panel...91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
whoa!!!!! not cool---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Last post july 2013... lol.. ok so back at her... where to start... I found some time to do some stuff, I removed the rear window, removed some of the rear deck by drilling out spot welds and stuff...strut towers are exposed and as you can see it ain't pretty.
I'm just going to lay a bunch of pics down and you will be able to figure it out I'm sure...91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
