coming by this aft...
WilyB's 93 GT rebuild
91 GT- Li'l Bee (under construction)
2013 Honda Accord V6 coupe - 14.7 sec. 1/4 mile
New Thread:
Wilyb's 91 Pro GT Rebuild: Li'l B: http://www.clubprotege.com/forum/sho...Rebuild-Li-l-B
Old Threads:
WilyB's 93 GT rebuild worklog : http://www.clubprotege.com/forum/sho...-93-GT-rebuild
My FE3 worklog thread:http://www.clubprotege.com/forum/sho...ighlight=wilyb
is that a true FE3 trans? or the F2 one? for some reason i remember the clutch slave line running up the side of that mount.
i know my F2T one does currently. something to maybe look into---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
New Thread:
Old Threads:
New Thread:
Old Threads:
New Thread:
Old Threads:
New Thread:
Old Threads:
Everything lines up, no cutting or hammering required!
I would have taken more pics but things went so well I didn't have time!! I want to than jump'ncrash for his help and his beer!! lol
Notice the clearance at the alternator and frame rail as well as the clearance on the opposite end at the frame rail and transmission!
The most difficult part was lining uo the tranny mount oles... but after loosening off all the mounts and x member bushings, everything fell in to place!!
Made a bit of a mess in the bay so I think I'll wait until the engine is wired up and running before final coat...
Looks like I have about 2 inches of clearance between the hood and the intake manifold. It's tighter at the timing gear cover... like pretty tight... less than an inch...
And I'll be putting my GTX famillia strut bar up for sale... it for sure won't fit...
Frig that engine looks big in there.... WAY COOL!!!91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
dun dun dun!!!!! Wicked to see phil. glad to have a 2nd FE3'd BG this side of the world.
there might be a significant difference between rake angle on the 323/protege hood enough that would make mine not clear for the timing cover. be weary you might have to run the top half with an open/exposed timing belt---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Yeah thanks!!
Next is the wiring... gulp...any electrical gurus I can bounce question off of ?
I guess it's 1A first on the 22 pin...lol91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
what about 1A ???---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
1A as in I start from the first pin on the first plug and make my way to the end...one wire at a time...91 GT- Li'l Bee (under construction)
New Thread:
Old Threads:
looks awesome man!!!-Jack
