wow that is one sexy rear end!
323Permin's 323 SE transformation into a GT
torch is a beautiful thing91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Yup a torch and a heavy duty hydraulic press does the trick ... I had the same problem . The steel sleeves rust on the the bolt and are fused to the bolt .
I ended up taking both to a machine shop to get them off ...
Hope you can have better luck with a torch and hammer ... but odds are you will have to get new bolts from pounding on them so hard .
The Suspension Install Begins Now !!!
Its about time for the install .... started on it last week and ran into a few issues . Some rust in the rear strut wells . It was to be excepted and I did fine some ... lucky enough that it was not to bad .. I was able to grind it away and clean it up .
Unfortunately the rear strut spring top hat were bad enough that I am not going to use them ... had to order up some new ones .. so thats been my delay now . I will have all the suspension buttoned up by this weekend .. so lots more pictures to follow .
- Likes 1
Originally posted by Lex View PostWhen you install the new suspension, apply lots of grease between the strut hats and the body of the car where they mount. That should keep the rust from forming again.2012 Kia rio
2009 Nissan Frontier
1997 chaparral 180LE
