Originally posted by Dan [Sac]
View Post
Not sure what you mean by that. I'm using the MX3 spindles. There is no physical room to insert the stud in the hub hole because the spindle is so close to the hub. To get the stud in the hole, the hub has to be pressed off the spindle, so there is no physical interference with the stud as it slides in. Seating it is child's play with an open ended lug nut and the air gun.'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
Here is what I mean on the stud:
Today's work - got the front calipers rebuilt, silver coated, and new pads & rotors put on. Goodridge lines also went on, brake prop. valve, and front hard lines. Still have to do a couple of things to the system (bleed master, and add the clutch lines & slave cyl).
looking great as always dan. let me know what you think of the k sports when you have this baby all done. was considering these for my pro but looking for input on them first. That and some cash lol91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
that's some solid progress!-Jack
Isnt it a bummer on the wheel stud,,, I was quite dumbfounded myself at first ,,,thinking there's has to be a way to get this in,, So i looked at it for 15 minutes feeling like an idiot,,, then over to the press I went... From then on its always antiseize and hand turning...Last edited by mxrx37; 04-26-2010, 09:54 PM.
Mx-3 Kl Turbo (Under the Knife Once Again)
94 Rx7 All Stock Montego Blue Touring Model
93 Lx
Originally posted by mxrx37 View PostI was quite dumbfounded myself at first ,,,thinking there's has to be a way to get this in,, So i looked at it for 15 minutes feeling like an idiot
I did the same thing, I was thinking that I'm missing something very obvious.
I've had KSports on a daily driven Probe before, and I found them to be a bit harsh, but I had low profile tires and 18" wheels at the time (40-series tires). They were fantastic on smooth roads, but with lots of potholes at the time, I was worried about my rims a lot. That's one of the reasons I went with the 50-series tires this time (also for gearing).'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
It's the spindle that's in the way, not the shield....if it was just the shield, my little friend the Dremel would have made a notch in there in no time. There is no access 360-degrees around. I think the BG & 4-cyl MX3s have smaller spindles than the V6 version.'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
Today's work:
*got the steering system 100% complete now. Rack connected to steering column via a double u-joint from a mazda 929 (I think) with an adjustable length (0-1" of play, which helped). Also made a plate to secure the end of the steering column (MX3) to the pedal assembly (323). Also made the firewall plate for the u-joint to go through. With the steering wheel on, steering is finally 100% functional and the short ratio rack should be a pleasure to drive on.
*got the blower mounted back in, and the interior wiring harness routed by the pedal assembly.
*hydraulic system also complete, with 2 custom short lines from the brake prop valve to the brake master cylinder (the 15/16" MC upgrade from the MX3 is nice, in case i do big brakes in the future).
Next up, I gotta make a round hole, then file it square (rectangular, actually) for the throttle cable fitting. Then mount the heater core, connect blower to heater core, and mount the firewall HVAC ducting.
It's coming together'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
nice progress man! sounds like you showed your steering system who's boss lol-Jack
