Very nice work like always!!
Originally posted by mazda323t View PostDan [Sac]
hey bro i see that you have the same set up that i want (kl to a mazda 323)i have a question. do it need the front end of the mx3 in order to fit that engine? or can i use a mx front end?? what extra part you used for make it happen... im sorry i a bordering you, but i want to try
basically you need a v6 mx3 parts car. cause you need the crossmember, shifter linkage, engine wiring, mounts, passenger side actual frame bracket, midshaft, and passenger side axle. for the drivers side axle, you will need a mtx BP kia sophia axle. your stock suspension/ or whatever you already have will work fine with this set up.~PaTricK~
-Current car's-
What are you driving?
hey bro i see that you have the same set up that i want (kl to a mazda 323)i have a question. do it need the front end of the mx3 in order to fit that engine? or can i use a mx front end?? what extra part you used for make it happen... im sorry i a bordering you, but i want to try1993 Protege LX-Midnight's shadow SOLD
Originally posted by Turpro View Post49 pages in dan's build thread and numerous other v6 swap build threads and you still can't read? *facepalm*
hmmm...? threadjack..lol
'88 323 sedan, K-swapped..
turpro
don't be selfish men, if you did the v6 swap without help good for you but if you don't want to answer question from rookies when you see that question if you don;t have nothing goo to say don't say anything..
i read a lot about it but im asking to whom really did that
Originally posted by monoxidechild View Postbasically you need a v6 mx3 parts car. cause you need the crossmember, shifter linkage, engine wiring, mounts, passenger side actual frame bracket, midshaft, and passenger side axle. for the drivers side axle, you will need a mtx BP kia sophia axle. your stock suspension/ or whatever you already have will work fine with this set up.
no. maybe the harness. and 1 or 2 of the mounts maybe, but thats about it. the v6 mx3 crossmember, shift linkage, bracket mount, and passenger axle are specific to only that car. the probe/mx6 versions are different, and wont work.
the biggest head ache doing the swap is figuring out a radiator set up in all truth. anyone with a decent grip on mechanics can do this swap. me and pile of rd1 got his done in a week. while working full time job's, and being baked through the entire thing. lol. hell, the BP was pulled, and KL was fully bolted in, in the 1st 24 hours. which was only 24 hour's after deciding to do it in the 1st place! haha!!~PaTricK~
-Current car's-
Srsly. GUyz.
If you honestly read this entire thread, as well as my old thread with the red 323 and searched as you say you have and still don't see how it comes together, perhaps this endeavor is not ready for you yet. Start small, like all of us did.
My first mod, and I was proud as **** when I did it, was a home depot 'cold air' intake with HVAC flex ducting and those plumbing rubber boots. I didn't even know what a clutch was back then.
Everything you need is contained here in the BG worklogs forum.'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
