klze swap
    It does matter which side of the rad the fan is on. If at all possible it should be behind it. Fans are more efficent as pullers then they are as pushers. Also your car moving can cool itself down. Having a fan on the front of the rad blocks the incoming air that would have naturally cooled the car down.
      Ididnt really think about it like that. I guess every little bit counts.
        hmm, thats good to know, ill have to go move mine to the inside (facing torwards the engine bay)
        i was also think by it being a puller and it being on the outside of the rad, doesnt that affect the cooler
        i mean think about it, its pulling air, but when your moving your jsut pushing air right back at it
        1996 V6 Escort
        1993 escort wagon DE/ZE hyrbid, ported heads, 5 lbs
          If the fan is a pusher it will be on the front of the rad pushing air though the core. If it is a puller it will be on the inside of the rad pulling the air though the core. Some aftermarket fans are reversable by changing the wires around, or removing the blade and turning it upside down and putting it back on. Sounds like you have a puller on the wrong side of the rad I would get a sheet of paper and see if it gets sucked into the rad or blown away from it. If the paper gets blown away from the rad you need to make some changes. All this talk of sucking and blowing has got me thinking about getting my Gurl friend some flowers.
            a guy with a v6 protege just joined the club, running a neon rad under the rad support, fit no problem!
              with no a/c. actually with no a/c you can get a monster custom rad in there. thick ass core and running the whole lenth of the support with twin fans. if i ever do this again or sometime in the future remove the a/c then thats what i will do
                I plan on running A/C. The rad is off a neon I'm running two fans in the inside.
                  man that tight if you want to run an a/c condensor. its tucked in nicely in the rad support though. what upper rad hose you running?
                    O.K 323Foreword Start talkin' LOL What year of Neon is the rad from? What engine option? Did The Neon have A/C or no A/C?? What car is the upper rad hose from?? Oh ya, welcome to the forum, nice 323
                      yea i switched it around, so everything is good now
                      sorry for the confusion but thanks for the help!
                      1996 V6 Escort
                        Lol 323foreward has been with us since 04 and has had serveral hot 323's
                        I think I might give the neon rad a try
                          I was misled "a guy with a v6 protege just joined the club, running a neon rad under the rad support, fit no problem!"
                          I have seen the Neon rad in A 326's before, but I have an allergy to these, so my interest was not there. LOL
                            Mazdapr is the "new guy" with a neon rad also. PR is pretty small, most of them know each other
                              also what do you plan on doing for guages?
                              all aftermarket?
                              casue im getting sick of my huge ass tach and speedo
                              1996 V6 Escort
                                I been around for awhile. I had couple of mazdas one for them was ride of the month.
                                I'm not sure exactly whats the top hose is from but I hope my pictures help.
                                I think the other guy with v6 protege is from chitown.
                                You can also go with the civic rad with factory civic a/c stuff.
