Well i ended getting the rad hoses sorted out, mocked them in place and put them together. all i need now is a rad cap and some antifreeze will go in. hooked up one of the a/c lines and fitted it all hopfully for good. still need to paint the center bracket and mount it and sort some of the wiring. also have to finish off and paint the upper rad brackets since they look like crap. took a pic of the lower rad support so you can see how its tucked in. also have a pic with the lights and grill to see how it all fits.
klze swap
Damn, tighter than Wesley Snipes' sphincter during a tax audit!
Nice to see it come together, props for doing it all while keeping the latch and A/C to boot!'90 Mazda 323 - V6 KLDE, supercharged, right-hand drive, build log
looks shockingly similar to the neon radiator. cept the neon one is alot easier to fit. and tucks into the radiator support better. still very nice job though. cant wait to see it all done~PaTricK~
-Current car's-
What are you driving?
Great job, and a look into my very near futureDominic Toretto rocks a MaZda and his cell phone number starts in "(323)"
Originally posted by monoxidechild View Postlooks shockingly similar to the neon radiator. cept the neon one is alot easier to fit. and tucks into the radiator support better. still very nice job though. cant wait to see it all done91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
Originally posted by Dan [Sac] View PostDamn, tighter than Wesley Snipes' sphincter during a tax audit!
Nice to see it come together, props for doing it all while keeping the latch and A/C to boot!Cincinnati, ohio Bengals for life
"Who Dey"
Originally posted by progt91 View PostI really disliked how the rad hoses were ran on the cars with the neon rad installed. i alway seen the upper rad hose running over the valve cover and then around the from of it as well.
we routed a burp tank off a probe though. and your mounts look way better. all that was done on piles was bend some flat stock, and drill some holes. would have been sweet to have a welder though.Last edited by monoxidechild; 08-07-2010, 10:30 AM.~PaTricK~
-Current car's-
wow turned out real clean! good job man-Jack
Originally posted by monoxidechild View Postthats only the other hack jobs. lol. we got pile's routed pretty much exactly like yours is.
we routed a burp tank off a probe though. and your mounts look way better. all that was done on piles was bend some flat stock, and drill some holes. would have been sweet to have a welder though.91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
got some antifreeze in it and had it run for a decent amount of time. all looks good so far and up to today there are no leaks91 protege gt. dropzone mx3 springs, mx3 crossmember, ractive front and rear strut braces, rear lower mx3 brace, 4 wheel disc brakes, corksport ss brake and clutch lines,kvr front pads, ractive cai,ram air hood scoop, modified front bumper, shaved ant and rear trunk lock, fubu ant, short shifter, corksport bronzeoil shifter bushings,92 glass sunroof and tail lights, mx3 center console, autometer gauges (volt and oil pressure) cluster needles painted to match, sound system, 17 inch eagle alloy 193 with 205 40 17 rubber. klze is ALIVE BABY!! . http://www.cardomain.com/ride/2394656http://www.toprotege.com/forums/show...hlight=project[url]
nice man! glad there aren't any leaks-Jack
need a frankensmiley---------- ITS ALIVE!!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
