Dam, looks like the escort keeps moving up in the world since I joined 9 years ago on feoa . Great work btw
Toyota E153 transmission swap
oil pump is out, but one of the screws which hold the steel cover to the housing almost stripped on me. later, with an impact driver, i was able to get all of them out including the damaged one.
does anyone have the part number for these phillips head bolts? i'd really like to just replace all of them.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
thanks!Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
no it wont, i'm pretty sure the corolla alltrac used some form of the 4AG
this adapter plate will work with 3SGTE and 1MZFE transmissions
...how rotted out btw?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
I just texted him and he said it might be a camry, did they make an AWD Camry?
according to wikipedia the camry all trac had a 3S-FE? a whole other animal I suppose?Last edited by nerd racing; 09-07-2009, 11:38 PM.2011 BMW 128i 6 Speed Manual -- dd
1990 Protege 4WD 5 Speed
Originally posted by nerd racing View PostI just texted him and he said it might be a camry, did they make an AWD Camry?
according to wikipedia the camry all trac had a 3S-FE? a whole other animal I suppose?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i havent seen many in the area, i almost wonder if its one of our old ones, they were out your way nerd.... the ones we had were 85 camry all trac 5 speeds, therye about the size of the old 323 but boxy, i was wondering about those parts for the pro's too.... see if theye tan or dark brown, id probably even recongnise one ...92 protege lx-
94 protege lx-
ok so we made a ton of progress today i will have pics after dinner
we are having some clearance issues and i need some opinions. would it be better to move the entire drivetrain forward ~1" or up ~1"? i am pretty sure either will cure our clearance problems (inner cv joints vs. subframe)Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
