Wow, that's just superb.
Toyota E153 transmission swap
just cut it and box it, toyota guys do it all the time its probably stronger then heating and weakening the stock frame rails
________
LEONELast edited by Blazin674; 05-02-2011, 08:29 AM.1995 escort wagon gtr/holset
1990 4wd pro - daily beater/monster car/mud buggy( sold)
1993 323(sold)
I'm buying parts i don't need, With money I don't have, To impress people I don't know.
Some people are like slinkies. They're not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
looking awesome man!!!!-Jack
i can give you the contact info of the guy who made the plate.
as far as mounts and all that, i MAY be selling kits sometime in the future... but obviously we have to finish my car first and make sure it all works.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
today was a very productive day.
first i got the engine moved around and tied in place with various ropes and straps. then i installed both axles, and triple checked my measurements and clearances. then we went ahead and made the passenger side and drivers side upper mounts. they came out REALLY slick and they are extremely solid... the drivers side mount looks a little "complicated" because i wanted to keep the bracket for the battery tray.
all in all we ended up moving it less than 1" up and less than 1" forward. i could have moved it less (possibly not at all) if i had cut into the K frame.
unfortunately i forgot to put the memory card back in my camera this morning... so i dont have any new pics . i'll just have to take some extras tomorrow.
tomorrow it all comes back out for some final clearancing of the drivers side frame rail, then goes back in so we can build the crossmember and front/rear mounts. i am a little concerned about axle bind, but i will need to get it down on the ground before i can make a final assessment. worst case, i'll need to buy some RX7 ball joints and 3rd gen escort spindles.Last edited by therieldeal; 09-09-2009, 10:53 PM.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
Originally posted by rally-gtx View PostIf you're looking to buy an adapter plate please contact Derrick at Corksport. I sold him the 3 extra plates I made. I have no idea how many of them are already spoken for though.
-Tim
i never was planning to make or sell the plates, if i were to make mounts it would hinge on Tim being willing to make more plates.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
i'd call CS first, if they dont have any left then talk to Tim.... if i had to take a guess he would probably want to do another small run rather than a one-offEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
another very productive day!
the new crossmember and front/rear mounts are all but done. just need to pull everything apart again so we can finish the welding that couldn't be reached with the parts on the car.
tomorrow i need to install the oil pump back into the GTR motor, install the LSD in the transmission, and try to get everything bolted back together. this weekend will consist of finishing touches, fluids, and getting it running again.
PICS!
cables routed through firewall
passenger side mount w/ steel spacers
trans side bracket for drivers side mount
frame rail bracket for drivers side mount (ugly but functional, retains stock battery tray)
axles
partially finished shifter mounting plate
shifter mounted, M10 x 1.25 bolt welded to the top so i can use my stock shift knob
drivers side mount installed
passenger side mount installed
front mount installed
rear mount installed, you can see the limited steering rack clearance
dim shot of the crossmember... camera battery was dying and wouldn't let me use flash anymoreEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
