not sure
Toyota E153 transmission swap
ahh okay
no one can get the damn things, i'd try the dealer but without part numbers i doubt they could figure out wtf i am talking about lolEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
what year/car did this tranny come from? I'm assuming a 90-95 MR2 (SW20)?
Try toyodiy.com for parts numbers...
90179-22015 for the nut.
42428-14010 for the cap.
My AE86 uses a similar setup for the front hub/spindle.
If nothing else, you could get a large flatwasher, drill it out to fit the diameter of the axle, then use the toyota setup on top of that, so you'd have a flat area against the hub, if the nut itself is too skinny...
--sargeLast edited by SgtRauksauff; 09-14-2009, 07:31 PM.
holy crap sarge, i've been trying like hell to find a website like that lol... thanks!
the axles are actually front ST185 axles.
90170-19002 for the nut
43525-16010 cap
i wish i hadn't spent 20 bucks on mcmaster carr a couple hours ago lolEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
so the shifter is all set after redoing the mounting plate
clutch is bled, seems to actuate just like stock. the pedal feels kind of soft but i've also messed with the slave cyl size and the length of the throwout arm. i'm just hoping that this pressure plate clamps as hard as its supposed to, a soft pedal always throws me off.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
hooked up speedo cable and some wiring etcEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
yeah i am waiting on some hose from mike so that i can hook up my fuel rail. also waiting on 3rd gen spindles and rx7 ball joints from georonimoEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
1990 4wd pro - daily beater/monster car/mud buggy( sold)
1993 323(sold)
I'm buying parts i don't need, With money I don't have, To impress people I don't know.
Some people are like slinkies. They're not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
lol it'll be done soon enough...
if i could FIND my stock fuel rail i'd throw it together with that temporarilyEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
not really looking to buy something that i'd run for less than a week and then throw away lolEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
fuel hose is in the mail
working on these damn 99 escort spindles...what a mess. i have to stop by ford tomorrow to get new snap rings and grease seals so i can put the new wheel bearings in. in the meantime i've cleaned them up alright, and they will be getting either paint or powdercoatEscort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
