good deal man! I want to see this thing get up and go!
Toyota E153 transmission swap
Originally posted by therieldeal View Postjeez guys if you want to talk about the fe3 lets start a new thread lol
in other news, i am hoping to have the plate in my hands by the end of next week. i have the week of labor day scheduled off from work (has been for months) so the timing seems to have worked out just perfectly!
________
Weed VaporizersLast edited by Blazin674; 05-02-2011, 08:29 AM.1995 escort wagon gtr/holset
1990 4wd pro - daily beater/monster car/mud buggy( sold)
1993 323(sold)
I'm buying parts i don't need, With money I don't have, To impress people I don't know.
Some people are like slinkies. They're not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
tracking number received.. its on its way!Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
:d-Jack
1993 323(sold)
so this project has finally picked up a little pace...
yesterday i finally paid for my toyota adapter plate
today i ordered some brand new 600cc deatschwerks injectors from boundary-engineering, and some universal poly bushings to fit inside 1.5" DOM tubing for my new custom engine mounts. i bought four bushing sets just in case we have time to (or need to) redo the passenger side mount.
i'm about to place an order with an online toyota dealer for a teeny speedometer drive component, throwout bearing, and some transmission seals. i already have some billet oil pump gears from boundary-engineering, which will hopefully be going in at the same time as the rest of this stuff.
conveniently, the guy doing the fab work for the mounts is someone i see often. we've been discussing designs for the new engine cradle this evening. i think we may try to incorporate a crosspiece that connects the ends of the K-frame together, like the mazdaracer bar except welded directly to the engine cradle with some gussets. this way it would be even stronger and more stable, and wouldn't reduce my ground clearance at all. it would also make it really easy to add a thin aluminum or plastic pan under the whole engine bay, to help keep things clean. what do you guys think of this idea?Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
If you're going to be driving this on the street when it's finished I wouldn't add new plates underneath without doing a bit of testing first to see how it changes under hood airflow. You can end up helping or hurting cooling efficiency dramatically depending on the design of the tray added. http://autospeed.com/cms/A_2159/article.html http://autospeed.com/cms/A_2160/article.html These are some good reads on the subject. If you really want to design an undertray, I have one of the same gauges they use for testing you can borrow.Not the sports page Not a magazine
its coming from CA to CT via ups ground... takes a while. due to arrive on friday.Escort GTR -- 11.87 @ 117.6 mph -- 320 HP / 325 Ft. Lbs. @ 23 PSI
