That thing rips hard haha. Any guess as to how much hp it's making? It "sounds" like over 300 at the wheels for sure.
Mazdasly75's GT-R
Here we go! I did G-tech pass to compare the evolution of the project. Here's screen shot of the results, the black run is the previous VJ23 setup set to 20psi, the red run is the new GT3076 set to stock wastegate 10psi and green run is the GT3076 set to 14psi. As you noticed, the start is slower cause I didn't hard launched the clutch like the black run. From 10psi to 14 psi, the car gained almost a full second on the 1/4mile. The speed per gears is higher due to the gain in RPM. Was shifting gears at 6750 with the VJ23 and 8000 with the Garrett. Right now, the cams needs to get timed properly, there will be huge gain over that and that's my next step tomorrow...yes I'm gonna pull the engine out of it's engine bay for maby the 10th times and there's 2 reasons for that; You'll probably ask me "why don't you have 20psi run?" the main fact is my transmission past away doing that 20psi run...BOOM! there she goes, right on the launch...again anyway to get the cams timed right on the spot, I need to get the engine out to install the degree wheel and that was the 2nd reason...more pictures to comes on "how to set cams with degree wheel".
Another big news, I'm about to buy a new car: ST185 GT4 to fix the transmission problem. Going to see what the car looks like today but will definitely buy it. I'm gonna fix the tranny for now, will drive it slow till storage and the swap will start this winter.
US graph
Metric graph
Speed vs time
Torque & HP graph
You'll notice here how much more HP this car does now and how far max output is @ 14 psi
Enjoy!Last edited by mazdasly75; 10-21-2011, 11:28 AM.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
-2008 Mitsubishi Evolution X MR, AEM turbo inlet system, 3" magnaflow exhaust.
-2006 Pimped Grand Caravan 3.8L GT40...I'm kidding, it's stock
Yesterday, I lifted the car and been listening the the transmission for diagnose. The noise comes from the transfer box, thats for sure, I'll fix it when I'll get time. So here's the latest work I did, a transmission swap...again, I put back the GT-Ae close ratio tranny. Before I install back the engine I timed the cams properly with the degree wheel. You'll understand why you have to do this while the engine's out of the car, due to its diameter size. Here's a few shots...
The GT-Ae tranny, still has its tag.
Had to tune the car a little to match the new cams timing, I now noticed a gain in torque at low engine speed, but wil be hard to know if there's gain over the OEM transmission as the gears ratio are different so G-tech will read different. The car's tuned for 20psi now and I want to run it until this winter for the GT4 transmission conversion. I'll take a few 20psi run on video, stay tuned.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
Originally posted by theredrocket View PostYou will definately see a benefit when you get the timing nailed down at 14psi I would think. 14psi on the gt3076 should be good for 320-340 whp. In a 2600lb car, I bet you will be in the 11's in the quarter.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
Just did a 20 psi 30-180km/h, girlfriend was sitting in the car, didn't wanted me to boost 20psi cause she's scared the car blows another transmission, lol. Notice how the 1st-2nd-3rd gears are close together. This is very funny to drive that, but I wouldn't think to have those gears in a FWD
CLICK THE IMAGE BELOW
Last edited by mazdasly75; 02-24-2012, 06:19 PM.-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
Had this laying down in the end of the "what to do" list, so today i changed the GT-R 0-180km/h speedometer for one from protegé GT 0-230km/h. I also swapped the tach as MDS killed the stock tach after a few minutes...it appear that this one didn't like the Nascar MSD high voltage box neither, died as I turned the IGN on "ON" position...PAOW! lol!
Hey mazdasly, what rpm have you taken the car up to? In that video you say the turbo spools from 4500-9000. Does the cars power start to fall off hard before 9000, or does it pull strong all the way to 9000 rpm? In the video it looks like you shift at ~8000rpm. If it does have power all the way to 9000, that's pretty awesome!Tyler has spoken
Originally posted by nickz View PostYeah a 8-9k rpm redline may be cool but streetable, guys?Give me a little more grunt in the bottom,the awd excells in putting the power down.A 8-9k redline turns your awd into a highway star.That aint my car.Correct me if I'm wrong.Tyler has spoken
Believe me it is streetable the engine is 2L now and there's no valve overlap so no low end loss at all. At 3000 the engine get 8-10 psi, at that level it's stronger than an atmospheric engine. That turbo isn't lagger than the VJ23, it's more efficient. According to the g-tech graph, 14psi get its max torque at 5100rpm and maxed out the ponies at 7150 rpm. That mark is raised at 7500rpm at 20psi. And the shift light comes on at 7800. After a gear ****f, engine drop to 5500-6000 exactly in the torque curve which is perfect.
I installed that turbo for what i expected, it blows off the speedo in les than 20 sec. You need a strong car to get in front of it, i can tell ya and i like it. There's probably a better turbo for that engine but i ain't gonna spend a dime into that deep research. Also next year i'll get the car to a dyno to tune the cams, there's lot of ponies to wake up, i expect to find extra 50.
I'll make another video while driving at normal speed you see that the engine isn't suffering of anything.
Thanks for sharing your opinion guy!-1993 Familia GT-R, 3" stainless exaust, 0.100" oversize Supertech pistons, ported and polished head, "hemi" style combustion chamber, Supertech 1mm oversize valves, megasquirt, 880cc low-z, MSD HVC, custom SS ramhorn turbo manifold, GT3076R ar.63, 25psi, 3" SS custom exhaust. Soon to be MS3X, COP and 28psi!
