See if you can make it fit with the battery in the stock location.
Mazda_Powered's 91 Protege LX
can do! I have a battery tray kickin' around somewhere. How tall is the stock battery? 6" or so?-Jack
Another way to get around the ps line is do what I'm going to do(if I decied to go ps or not) is buy a cheap 15 dollar ps cooler. They're finned and are only like 7x2.51993 Protege LX-Midnight's shadow SOLD
yea definitely could use a cooler too and have it offset to the passengers side, or where ever you really wanted it.
Well today is a record for me lol, haven't been up this early in a while. Idk if I'll be doing much outdoor work today, as it is REALLY REALLY COLD lol.-Jack
Dam I don't check in for a week and you get the engine installed, I should wait one more week to check in so it'll be running lol
1988 323 GT - B6T Powered
I wish haha, I'm still contemplating on pulling out both harnesses to work on them indoors. Both need soldering still lol.
Soon tho! I hope end of this month the car will just be waiting on ECU signal-Jack
yea i would do it inside was doing mine out side and broke 4 wires -_-handed down to my old man : 1994 Escort gt
Race car: 1991 EGT BP/bpt
http://www.wihandyman.com/forum/show...racecar-s-life
daily: 2004 mazda 6
http://www.wihandyman.com/forum/show...678-TheSexySix
Welcome to Canada
''It's a shame that today's car forums have "fashionistas" instead of gear heads''
ya I've already damaged a transmission sensor wire, so i've gotta pull that to fix it lol. Luckily there's about 2" of wire off the sensor left.-Jack
I keep making turbo noises when I drive my parents Oldsmobile. I think I'm getting excited or something.
Today didn't anything today tho...
Here's the next list of things to do tho
-Pull engine harness for solder work
-Connect oil gauge to block fitting
-Add oil and filter
-Remove short shifter (Trading)
-Pull front spindles for bearing r&r
-Clean up axles & install (add fluid once system is sealed)
-Bleed the clutch
-Power starter to prime the engine with oil (it's been sitting for a bit, same with the turbo, kind of paranoid, plus I wanna check if my oil gauge works lol.
Then I get to deal with my fender harnesses...ugh lol, those aren't done yet and I kinda need headlights/signals for safety...plus the accessories too lol.
OH YA! Got my inner/outter tie rods coming in the mail along with that stupid $40 turbo coupler, boost controller, gtx/t3 adapter (future project lol), and 4300K HID bulbs (have ballasts in the 626 lol)
There may be more stuff I'm missing...oh ya! Type S BOV and flange are coming too! I plan on disassembling it and taking lots of pics. I wanna check the diaphragm.Last edited by Mazda_Powered; 03-03-2011, 10:26 PM.-Jack
do you have a projector head light if you dont you may have problems with the police with the projector it has a cut off in it so it can be aimed at the proper height http://www.youtube.com/watch?v=imIiglkq7HAhanded down to my old man : 1994 Escort gt
daily: 2004 mazda 6
Welcome to Canada
yea I don't have the stuff to do a retrofit yet, I traded my clear lenses for the GTX ECU, which I need a bit more than the lenses.
I've never had any issues with police and headlights though, a lot of people run non-proper HIDs. Hell you can buy a plug n play kit locally for $100 installed. My 626 drove around for 7 months without any complaints either...no one flashed me either.-Jack
Originally posted by Mazda_Powered View Postyea I don't have the stuff to do a retrofit yet, I traded my clear lenses for the GTX ECU, which I need a bit more than the lenses.
I've never had any issues with police and headlights though, a lot of people run non-proper HIDs. Hell you can buy a plug n play kit locally for $100 installed. My 626 drove around for 7 months without any complaints either...no one flashed me either.handed down to my old man : 1994 Escort gt
daily: 2004 mazda 6
Welcome to Canada
Well did some more work today
Removed the harness and ecu
here's 2 of the plugs I have to solder on
still have to swap the brackets over
Oil gauge is now fully installed
Also installed the rad/hoses to check clearance...holy **** it's gonna be tight for the lower IC pipe...
Had to remove the auto tranny cooler line for more room lol
Then started to fit my piping for measuring/cutting...
I'm only cutting a bit off at a time, started with around 2" off the 90 degree pipe
Then I cut 3" off the 45 that's tucked under the fender pocket
I had to really cut down the 45 bend that connects upper to lower pipe, I believe it was 6" off the one end, and 8" off the longer end
It made for a real nice fit tho...can't complain since it doesn't hit anything and the inlet is pointing out straight
So for people wanting to keep their stock battery, all you would have to do is cut more off the 90 degree pipe at the throttle body to bring the pipe closer to the engine. The center 45 would be roughly the same size, maybe 1" longer. Then you would only have to cut off about 1" off the 45 that tucks in the pocket.
Still have a good amount of piping and couplers left for the turbo to IC pipe too!
So next task is to tackle the turbo to IC pipe, which will be a bit tricky...but I have enough bends to make it happen (I hope)-Jack
