Originally posted by jinx
View Post
Gambit's 93dx build
Pic of it next to my old 50 trim T3
Add me onmore pictures of my projects can be found there.
Nope.. long story short Precision screwed up my order and I decided to stay with the .63 housing that I got for now. I can get the .48 for like $250 overnight if I find out the .63 lags like a mofo. I did a fair bit of research on it, it's more popular with the srt4 guys and they are having a hard time getting it to spool before 4500 rpm with the .63 housing. So, we shall see what the BP thinks about it. There's no way in hell the gtx mani would work out with it, so I'm building a new ram horn mani for it this week :D and once that's done, it's back to the dyno to see what it's made of. 15 psi on this puppy would be like 18-19 psi on my old T3 and until I build the bottom up, it won't be seeing more than 21psi which is the limit for the current map sensor on my MS.
It's gonna lag a fair bit no matter what.. The real question is, just how much?? As I said to Ryan > If I wanted late spool, I'd of had a Supra ages ago
Originally posted by jinx View PostNope.. long story short Precision screwed up my order and I decided to stay with the .63 housing that I got for now. I can get the .48 for like $250 overnight if I find out the .63 lags like a mofo. I did a fair bit of research on it, it's more popular with the srt4 guys and they are having a hard time getting it to spool before 4500 rpm with the .63 housing. So, we shall see what the BP thinks about it. There's no way in hell the gtx mani would work out with it, so I'm building a new ram horn mani for it this week :D and once that's done, it's back to the dyno to see what it's made of. 15 psi on this puppy would be like 18-19 psi on my old T3 and until I build the bottom up, it won't be seeing more than 21psi which is the limit for the current map sensor on my MS.
I saw that. I think that the .63 will be fine. But the same guys telling me about this turbo rev to 8500. You got a 4 bolt housing I assume? What size downpipe are you going with?
Originally posted by jinx View PostIt's gonna lag a fair bit no matter what.. The real question is, just how much?? As I said to Ryan > If I wanted late spool, I'd of had a Supra ages ago
Speaking of supra. There was a 2jz swapped fd rx7 at the cs meet. I believe he was on a gt40r. Man that thing was an animal. It definately had the most bad ass dyno pulls ive ever seen. Once that turbo got spooled it sounded absolutely amazing and made about 600 wheel.Last edited by gambit686; 11-27-2011, 11:42 PM.
5 bolt no wastegate hole in hopes to salvage 90% of my old DP from the Garrett setup. The DP is 2.5"
Originally posted by gambit686 View PostLol Its got a big efficiency range and looks to come on like a freight train. I think that even if it spools a bit later it will be flowing a ****load of air in the meantime.
Looks good, Do you think 2.5 will be enough though? It would greatly benefit spool time going bigger with the downpipe. Or do you plan on doing a cut out? I think when I get it on Im gonna take it down to speedfactory and have them do the piping turbo to tail. I am Intrested to see what they have to say and how they set it up. The hondas they build are savage. There boosted hatch runs an 8. And I think they have the fastest NA setup. K24 that just broke into the 9's.
What size injectors are you using jinx?? I think im going to use 1000's on E85. But I need to do some reading on E85 because id also like to run water meth.
I have a Spec PP with some Exedy clutch disc (was part of a Centerforce setup- full-face on one side, puck on the other, sprung hub). It stands up to 1.8bar on the regular and has seen 2.5 without even a hint of slipping, and this is the fourth car that pressure plate has been in, lol (Pat's GT, my GT, Brandon's 4wd, and now the wagon).
That clutch is about as DGAF as I've ever seen.sigpic
92 240SX: KA/T25, nerd mobile
Originally posted by gambit686 View PostLooks good, Do you think 2.5 will be enough though? It would greatly benefit spool time going bigger with the downpipe. Or do you plan on doing a cut out? I think when I get it on Im gonna take it down to speedfactory and have them do the piping turbo to tail. I am Intrested to see what they have to say and how they set it up. The hondas they build are savage. There boosted hatch runs an 8. And I think they have the fastest NA setup. K24 that just broke into the 9's.
Originally posted by jinx View PostWe don't have emissions or inspection to deal with down here, so I don't have a cat or anything, just a straight through muffler at the end. It's 2.5" mandrel all the way back. It's the least restrictive that a 2.5" run is going to get besides just running a downpipe. My personal opinion is 3" is far too large for anything under 450-500hp, unless you have to deal with lots of restrictions in the path of the exhaust to pass smog and such. I'll be sticking with my exhaust! Right now I'm running DeatschWerks 800cc injectors and they should provide enough fuel for well past 400hp :D
Im not saying that the 2.5 is bad or anything at all. Im just saying that I think on a turbo that big and having a .63 housing, Spool time will suffer a small bit. I need to read through your build thread again to see what motor internals you have. You need to hurry up and start a part 2 of your build. I cant wait to see the progress on this thing.
