thanks, that sounds encouraging
Bo's awd protege
glad she's running smooth man!!! my GTX setup passed emissions testing under the n/a BP specs with a 220k OEM cat lol you should be fine-Jack
nice man!! probably sounds a lot smoother now. Now to work out the bugs?-Jack
what is the inside diameter of the strut tubes on a bg?
I wonder if you could buy a set of megans for a 240 and cut the bottom mount and weld them to the bg mount and get camber plates . my buddy's have done it with other carsLast edited by dislexicdime; 02-23-2012, 07:10 PM.
sohc pump would be scary! lol
ya ksports seems to be holding up pretty well in the BG chassis...if I stick to mine I'll probably do the same some day, just too many issues when you try to build your own setup it seems lol.-Jack
Originally posted by bogaut View Postdrove it home from exhaust shop yesterday. took about 5 minutes until i blew a damn coupler . it was the one right of the compressor, so im gonna try the hairspray method and see how that works.Create your own VB Gallery here.
you can make a bead roller with some old vicegrips, a muffler clamp sheet metal piece, and a big washer. just weld the clamp to the one side and the washer to the other. seem to work pretty well from what i'm told. i will be going that route when i get to ic piping.2011 BMW 128i 6 Speed Manual -- dd
1990 Protege 4WD 5 Speed
