droplink conversion it is!
300zx's ELX work log
Originally posted by FE3-323 View Postthat endlink is your critical problem....... period. the swaybar in these cars was never designed to be that far up from the control arm.
Im utterly surprised you haven't broken the swaybar yet. visually i can see the bar doesn't even look correctly anymore
you have 2 options really:
go back to the normal endlink design
change over to the later BJ design where its connected to the strut. (note this increases the swaybar ratio)
take my advice & ditch that system
The car is lowered which makes the control arm move up which in turn with the same length endlink, pushes the bar up the same amount. The bar is fine and is not distorted, where its hitting versus the force applied to it=very little leverage. The sway bar wont break till it wears a groove in it and creates a weak spot.
A normal endlink would have to be considerably shorter to work, and that would mean not even using poly bushings it would have to be so short.
I would only consider the BJ option if the MX3 bar wont work since I would have to buy a couple threaded endlink collars and come up with a new endlink or use a stock one I guess.
Originally posted by crazycanadian View PostI don't have any problems... My whole front sway bar/control arms and sub frame are all stock mx3 gs stuff..
Originally posted by concealer404 View PostI don't remember the stock endlinks placing the sway bar much closer to the arm. An inch at most closer.
I don't think he CAN go back to the stock endlink design. The only real option here without going BJ chassis style is finding a shorter body'd rodend.92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
Originally posted by Mazda_Powered View Postdroplink conversion it is!
Last resort at this point. I want to be finished with the suspension and move onto other areas92 Mazda MX3 GS> For sale, $1750 OBO
are you having issues with the bar hitting on the lower or upper segment of the subframe?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Finally got my new tires mounted and on the car, got the aluminum flywheel balanced and am hoping to finish installing the new Viper keyless entry system today.
Also got my engine rebuild kit as well, so I am very close at this point to starting the rebuild, just a couple small things need to be done first. Finish the head/reassemble and get the injectors cleaned.92 Mazda MX3 GS> For sale, $1750 OBO
awesome! how do you like the tires so far?-Jack
You never realize how bad your tires get over time till you install new ones. The improvement in the ride is welcome but I havnt pushed them yet so I cant say how they stack up vs the old set in the handling department.92 Mazda MX3 GS> For sale, $1750 OBO
Installed my Viper keyless entry, rerouted my oil pressure gauge sensor cable, installed green LED's in my cluster, and finally have a hazard light button again.92 Mazda MX3 GS> For sale, $1750 OBO
Got the Kia head finished and reassembled tonight. Only thing left at this point is to buy a scale and balance the Miata Pistons/rods and send the Kia injectors out to be cleaned. I tried cleaning the spare set of HLA's but I could only get 3 of the 16 apart, so I will be picking up a set of brand new ones from Ebay.
The plan is to rebuild this thing toward the end of July since I will be taking a 2 week vacation from work.
In other news, I have been trying to get a in contact with Colt Cams to get some Tri-flow regrinds to go with my rebuild but after 3 try's and no email response I may just forget it and stick with the stock cams.92 Mazda MX3 GS> For sale, $1750 OBO
I will have to get some international calling on my phone before i call them. I really want to try their cams, they have great reviews.92 Mazda MX3 GS> For sale, $1750 OBO
Finally received an email from Colt today and here are the specs given with a price:
To James.
Thank-you, for contacting us.
We offer a tri-flow grind that runs:
Prime Int: 288° .363 L
SEC INT: 274° .355 L
EXH: 288° .363 L
The cost is $420.00 US this includes the return shipping
This is for Hyd lifters !
Customer supplies cam cores
If you are interested please give us a call at your convenience.
Thank-you,
Geoff Bardal @
Colt Cams Inc92 Mazda MX3 GS> For sale, $1750 OBO
looking forward to your reviews on the tri flow's.... i recently read up on them & it crossed my mind for the FE3 head---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I will certainly give them a review, but I doubt I will do any dyno's of them. I plan to run the engine after the rebuild and get a feel for it and then swap them in.
Here is a stock AE86 dyno before and after of them:
fair nuff. a personal review from you will more then suffice---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
