what does the car idle at??
300zx's ELX work log
Its around 800-900 RPM92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
I messed with the VAF idle mixture screw and leaned out the idle some. seemed to take care of the issue enough to be livable.
So I adjusted the VAF 5 clicks CCW from its pre-rebuild setting to add more fuel and see how it runs. Just went and test drove it and it made absolutely no difference in the A/F ratio at WOT.
I also noticed this thing will stumble in the low end if you go wide open too fast. The A/F ratio will spike at 17:1 and then drop down to 14.5. If I ease into it before WOT it will give me 15:1 and then settle at 14.5.
I am thinking I maxed out my injectors from watching my fuel pressure gauge since its reporting as high as 50psi when I snap the throttle and 30-40 most other times.
Anybody have any suggestions or ideas? IDK what the Kia injectors are rated at but I though it was slightly more then the standard BP ones.92 Mazda MX3 GS> For sale, $1750 OBO
Proper tuning as in a MS? Thats obvious but is my lack of change in WOT fuel ratio an indicator of the injector not delivering enough fuel?
I know when I adjust the VAF its adding fuel because my idle will get richer but WOT is not changing.92 Mazda MX3 GS> For sale, $1750 OBO
Originally posted by 300zxrb26dett View PostProper tuning as in a MS? Thats obvious but is my lack of change in WOT fuel ratio an indicator of the injector not delivering enough fuel?
Bigger injectors might help, then you can try tuning the VAF to get your mid throttle happy.. IT's going to take some playing around to find the optimal set up where you can make everything happen..
I would then wonder if the stock ecu could handle bigger injectors properly. I have emissions coming up in november and I really feel the vaf tuning is not going to be able to help much. if the ecu is only looking at tables then anything I try is just going to be a hack and patch with this old system.
I wish I still had that set of gtx injectors, I would put them in and try it out just to see if it would work.
I have been looking today at buying a diypnp megasquirt from diyautotune. Seriously considering going this route......92 Mazda MX3 GS> For sale, $1750 OBO
I'm pretty sure from my experience that even at WOT the ECU still references the VAF. I was able to lean and enrich WOT AFRs quite a bit, with just VAF adjustment.
James, I would try an AFPR first of all. I had great success tuning with the AFPR and VAF. I was running E85 on a BP26 ECU with the A-code and 460's, without the AFPR, I'm sure that combo would have been a no-go.Current:
68 Torino GT Fastback
86 MR2
91 F150
94 Escort Wagon BP swap
99 Escort Wagon BP swap
00 Miata LS
08 Arrow AX8
14 Mazda5
Originally posted by bomdoutscort View PostDo you have an untampered with U code? I'd try that first.
Originally posted by CODY004WD View PostI'm pretty sure from my experience that even at WOT the ECU still references the VAF. I was able to lean and enrich WOT AFRs quite a bit, with just VAF adjustment.
This engine wants to breath but its not getting enough fuel for its full potential, so I am borrowing a set of GTX injectors to test out from azgtx on monday. If this works then I will have to find my own set of GTX or similar drop ins and purchase a MS to unlock the full potential. If it does not work then I will have to look elsewhere like the pump is not flowing enough (which I doubt) or the VAF is bad.
BTW I was looking at the a MS 2 DIY PNP and was wondering what is the difference between it and just getting the regular DIY kit with a Nippon Denso 76pin connector? price?92 Mazda MX3 GS> For sale, $1750 OBO
Originally posted by 300zxrb26dett View PostIf it does not work then I will have to look elsewhere like the pump is not flowing enough (which I doubt) or the VAF is bad.
Remember its not just how big your injectors are, but how long they are programed to be open as well...
So if the pump was not flowing enough then it would more then likely be getting leaner as the revs go up. If I apply the same logic to the fuel injectors, that would possibly mean the tuning is the only thing this needs. I will have to look again, but I think my A/F is steady at 14.3-14.5 all the way to redline.......92 Mazda MX3 GS> For sale, $1750 OBO
I.E. Try an adjustable fuel pressure regulator.
The Aeromotive one I had acted just like the stock regulator, meaning the rate would rise and drop with boost/vac. I could adjust the VAF to the point where the car would no longer Idle, then I would adjust base fuel pressure to bring it back to an Idle. Then I would take a run, log my AFR's with my camera phone, pull over, watch the run a few times, adjust the vaf, fix Idle with the AFPR, and do it again. I was leaning the Vaf, and adding fuel pressure BTW.
It took like 8 "runs" to dial-in E85, 10PSI, and 18*base timing advance, on a stock ECU without any piggybacks... And it Idled at 850RPM smooth and steady. I'm sure you can make your setup work without megasquirt. Although In your application, there is a lot to be gained by deleting the VAF. They are restrictive no matter the size.Current:
86 MR2
91 F150
00 Miata LS
08 Arrow AX8
14 Mazda5
Problem solved!
Installed some borrowed GTX injectors from another member today and thats exactly what the car wanted. More fuel. It now revs instantly from an idle with zero hesitation. Stabbing the throttle from idle now gives 12:1 approx where before it would go to 17:1. I also returned the VAF to its pre-rebuild setting and then going about 3 clicks leaner then that. Idle is no longer buttery smooth like before, but I kind of expected that with a N/A ECU controlling GTX injectors.
Because of this new development a MS 2 or 3 is in the future along with some DeatschWerks 350cc injectors, a brand new intake setup and an experiment I want to try with the exhaust. After that it will be ITB's
Unfortunately I cant do a test drive because my water pump just started to make a lovely scraping noise, so I will change that first.92 Mazda MX3 GS> For sale, $1750 OBO
