No problem. Those MT.net guys can be total assholes but they document things fairly clearly and completely.
300zx's ELX work log
1988 BF GTX
1990 x2 BG AWD Protege
1991 Escort GT- SOLD
2005 Corolla
Part number# ZM0111408
It can also be looked up under 2000 protege 1.6L
I actually installed it today on the Kia crank pulley I have and it is a perfect fit.
Almost finished assembling the MS3. It was a little more work then I anticipated converting it from a MS1 but pretty straight forward, just have to finish soldering all the wires to the BOB/adapter harness.92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
wish they had something like this for the FE3 :/---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I have never seen a pulley from an FE3. How much different is it from a BP?
Is there a chance that the Kia FE3 had something like this since it came in later years?92 Mazda MX3 GS> For sale, $1750 OBO
lol nope. the kia uses a pickup on the flywheel instead of on the crank pulley. its a neat idea. altho adds a bit more rotational weight into the scenario then a thin plate on the crank pulley.
regardless. right now i can't even utilize that since im running the H trans.
the FE3 has a 6 bolt crank pulley with a slightly uneven spacing. it might be feasible to retrofit this. but id almost need to buy one to directly compare it.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
The part cost me approx $20 shipped so its not that expensive. Might be worth a shot. Either that or get the universal weld on wheels, although if you have to weld it on you may as well weld this one.92 Mazda MX3 GS> For sale, $1750 OBO
I think i am going to change directions with this build.
Time to start collecting parts to drop in an F2/FE3 Hybrid engine.
Parts list:
1: Passenger side F2 bracket
2: Passenger side MX3 GS mount
3: F2 G-transmission
4: F2 engine and Kia FE3 head or just bolt the FE3 head to the F2 block at the JY and take it up to pay as a complete engine, haha92 Mazda MX3 GS> For sale, $1750 OBO
Since I want to stay N/A and the BP is honestly too expensive to get maximum displacement from it and your still limited to its terrible rod ratio in the end.
I can drop this combo in without doing anything to it and have more displacement then the BP can give me with a better rod ratio. Plus I can always increase the displacement over the 2.2L, and its cheaper. The BP will remain to help me get the MS running and tuned and then when I move back into a house again I can start working on the swap and the BP will be parted out.
Plus I think 2 of the cylinders in the BP are hosed and compression overall is a little low. I tried to cram too much stuff into 2 small of a time frame and had too many issues with little stuff that caused me to really miss my opportunity to break the engine in correctly as I was spending too much time with it idling in the driveway trying to work out all the bugs before I took it for its first test drive/break in run. On top of that 1 of the GTX injectors I installed to fix my fuel problem was leaking this whole time and just dumping into cylinder 2 and it has the lowest compression. Re-installed stock injectors to run in it for now and just drive it easy. It does however still feel better power wise then before the rebuild, but its for sure not what it should be. Oh and I think the crank pulley is no good either since I cant seem to set ignition timing correctly at all according to the mark on the pulley, plus it wobbles.
I suppose I could pull it apart run a ball hone down the cylinder bores and re-ring it but IDK if I want to now.Last edited by KAinjection; 10-28-2013, 09:06 PM.92 Mazda MX3 GS> For sale, $1750 OBO
I also want to find a MX-3 GS steering rack and steering column to swap into my car as well.92 Mazda MX3 GS> For sale, $1750 OBO
Reinstalled the catalytic converter yesterday and took it to emissions today.....I failed
Car barely failed the test, but here were the results: They go by Grams/Mile
HC---- .91 .80 Allowed
CO---- 6.44 12.00 Allowed
NOX---2.09 2.00 Allowed
I need to do some checking of my plug condition, check my compression and check my timing.
After installing the cat on the exhaust, which is my old cat so It reduces down from my 3" pipe to 2" at the cat inlet and outlet, I had to remove a lot of fuel with the VAF lol.92 Mazda MX3 GS> For sale, $1750 OBO
Originally posted by 300zxrb26dett View PostReinstalled the catalytic converter yesterday and took it to emissions today.....I failed
I wasnt suspecting the cat only because its less then 2 years old, but it is a cheap generic unit and the engine was burning some serious oil before the rebuild so maybe it is going bad....
I was thinking to try the alcohol in the tank and retarding the timing trick my coworker mentioned he did with his car.
The MX3 column you say? I would have never guessed I will have to check that out next junkyard trip.92 Mazda MX3 GS> For sale, $1750 OBO
