a good cleaning of the intake manifold & the head ports will definitely help. its time for you to invest in a catch can tho... your PCV system is putting alot of oil back into the motor.... that'll kill performance at a scary pace.
The 'scort with no name.....
Originally posted by FE3-323 View Posta good cleaning of the intake manifold & the head ports will definitely help. its time for you to invest in a catch can tho... your PCV system is putting alot of oil back into the motor.... that'll kill performance at a scary pace.1992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
anything really is better than just straight into the intake manifold... i have no preference.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
I bough a cheap ebay "Sickspeed" catchcan. Its just an open container. I made it better by making a divider out of some aluminum plate from top to bottom and then drilling some holes in it toward the bottom of the plate to connect the chambers, then I added some steel wool to each side and closed it back up. Works great.92 Mazda MX3 GS> For sale, $1750 OBO
Aluminum CAS/Distributor caps
BP oil jet eliminators
EV14 fuel rail spacers
More stuff coming soon.......
carb cleaner.... we don't have EGR in the intake manifold. so this isn't really a problem....---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
gotta love carb cleaner harsh on the lungs(don't use it in enclosed spaces) but it does clean like a mofo vs oil---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Yep, gots lots of learning to do.
I was under the impression the upper kia intake manifold was a direct swap over. Well, it's not. I've been doing some more research, and finding that the TB needs to have a triangular shape nub cut off.. Other than that, I'm working on understanding really all the difference of the two. What that canister is below the Mazda/Ford and why it's not on the kia.. Why some lines are not coming out of the kia but are on the mazda.. what that port in the bottom side of where the TB mounts to the mazda/ford unit is and why it's not on the kia. The Vac hoses on the top of the kia..
The more I think about doing to this build, the more I learn, I don't know jack.
Anyway... here is a collection of pics
the kia upper manifold is far superior. just getting around the throttle body issue is your only issue. theres a few people who've done the swap look around on here some more---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Check my ELX work log. I did it and there should be details92 Mazda MX3 GS> For sale, $1750 OBO
^ savior of the day!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
With acquiring new parts regularly.. I've finally hit the $3,000 mark on the entire car (including car). Now, if only it were done and being driven..1992 Ultra Blue Metallic EGT - The 'scort with no name - crap>reliable daily>rallycross prep>stage rally
Parts arrived today, compliment of GarageStar (GS)... Now, before I look like a dumb@$$ to them, I'll settle with looking like a dumb@$$ to you guys...
I ordered the lightweight pulleys for the NB. Alternator and Waterpump...
For starters, the GS pulleys are grooved, while my existing pulleys are not.. Did I maybe order the wrong kind???
And 2nd, I was under the impression the Alternator pulley (again ordered NB) would be identical. Well, the GS pulley is a one piece, and smaller than the oem that is a 2-piece.... Did i screw up somewhere??
