1-3-4-2 in the direction of the motors rotation on the disty
93 lx
Originally posted by azgtx View PostFiring order is right? Do not even look at that stuff setting the cam sprockets backwards, that is fookin nuts. The motor is designed to run the way it was built not backwards.Originally posted by FE3-323 View Post1-3-4-2 in the direction of the motors rotation on the disty
Is there anything that changes ignition timing during cranking or when cold? (I'll look through the FSM)
Sent from my m8wl using TapatalkClubProtege
by chance is your rotor loose inside the distributor??
I kept the OEM rotor retention spring as it actually worked vs some of the aftermarket crap ones... might be worth looking into.
that could certainly create a several degree variance---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by Dixie94Pro View PostI only replaced the ecu. The harness is stock
Enviado desde mi GT-S5830M usando Tapatalk 2
Originally posted by Dixie94Pro View PostReplaced:
valve cover gasket, intake hose, spark plugs, air filter, dome light bulb
got the a/c running perfectly
[ATTACH=CONFIG]66036[/ATTACH]
[ATTACH=CONFIG]66037[/ATTACH]
Bought turbo goodies :D
[ATTACH=CONFIG]66038[/ATTACH]
Originally posted by hips710 View PostWhat happen with your car
Enviado desde mi iPhone utilizando Tapatalk
Hopefully spending some time with it this weekend... Still don't know what's wrong with it though!
