whoa. suddenly your car started a diet
93 lx
while the trans is off, are you putting in a LSD??---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
return the fidanza, mail me up your flywheel & your differential. i'll lighten the stock flywheel for you & weld up the diff pin. /story & much more wallet.....---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postreturn the fidanza, mail me up your flywheel & your differential. i'll lighten the stock flywheel for you & weld up the diff pin. /story & much more wallet.....
Sent from my m8wl using TapatalkClubProtege
never too late to return it!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
Originally posted by FE3-323 View Postnever too late to return it!
I finally was able to get by the junkyard and get some MPV strut nuts.... And finally...
sweet!! looks good in there!!---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
i think the miata wheels are either 6 or 6.5" wide. 195 would probably be ideal for that.---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
So I picked my tires up, got them mounted and balanced, then noticed they mounted them all in one direction. Had to go back and get them to flip two of them around. FINALLY got them back. Put them on tonight Stripped the bolt in my jack had to finish with my 4runner jack (wasn't easy).
Ready to see them in the day, check the pressure, and drive around!
did you move into the new house now?---Has ClubProtege helped you in someway? show your support by Contributing--- Click Here---
