Stupid o2 sensor question
    You should hear a slight jiggle sound when you shake an o2 sensor? I've changed em before but never really noticed the sound I'm getting from the new one I've purchased. Never really shaken one before either...
    James G.
    sobe83@yahoo.com
    AIM: DVS 323BPT
    MySpace
    Cardomain
    <BR>
    <marquee>Turbonetics T3/T4, RC 550cc injectors, Walbro fuel pump, SSAutochrome Miata manifold, Tial 35mm wastegate, large FMIC, Apex-I SAFC, GReddy Type S BOV, 2.5" aluminum charge pipes, NGK plugs/wires, RX-7 VAM, 3" turbo-back exhaust, ARP head studs, H&R Springs, S/R struts, Sony XPlod deck-2/12" subs, Power Acoustic 800w amp, Pioneer speakers, Evo front bumper, ADR DV8 17" wheels.</marquee>
    Never heard any sound from the two I have laying around here...someone else correct me if I am wrong...
    JordyB
    '88 Mazda 323 GTX
    '91 Ford Escort BPT
      I don't believe thats right. I've taken apart an O2 sensor and don't see any reason why it should jiggle......unless conections are loose.
        my 3 wire gtx rattles and my brand new 4 wire rattles. should be ok i guess.
        00 dakota 4x4
        90 crx si - ls/vtec
          plug it in and see if it works. If it doesn't, you'll get a CEL.
          My MAM SS Kit Install Thread | Gauge Customization kit - LEDs, icons, more! Sample:
            CEL? check engine light?
            More Information
              yep
                Does anybody know why my o2 sensor is cut and no CEL light ever turned on?
                  bad phrasing. The o2 sensor is cut, does anybody have an idea why the CEL light never goes on? What else causes the engine light to go on?
                    interesting. just the heater portion of my o2 sensors failed, and both times the CEL lit.
                      then again you have a 99 pro where our cars are older...
                      More Information
                        true. It could be that the older computers don't even check for a working O2 sensor. I am sure someone else will have a better answer for you on this. I answered because I just replaced my second sensor two weeks ago.
                          i just went and unpluged my o2 sensor and my CEL did not come on....
                          More Information
                            It probably needs to be unplugged for a little while before it comes on if it does. I know that on my brothers Storm it wint come on for a faulty 02.
                              Same with me
                              Paul S.- New Canadian Dropzone distributor
                              1989 Celica Alltrac (Turbo AWD) MODDED!!
                              93 Escort GT- K&N, modded intake, poly-filled motor mounts, new clutch, energy suspension rear sway bar bushing set, 2 MX-3 seats, clear corners, custom 1/4" wheel spacers.
