I finally got my car running and am having a problem with it.
As some of you know I put the 99+ Solid lifters and cams in it. Well the problem I have is The car idles fine and cruises fine, but whenever I am in gear and try to accelerate past about 1/4 throttle No matter how much gas I give it it will not accelerate quicker. Everything is on timing (if I was using stock cams) and hooked up right, so I have the impression that it is from the cams, and it needs to be timed differently.
I was wondering if anyone on here that has done the swap had the same problem and knows how to fix it. I guess if I have to buy cam gears, then that's what i'll do. But does anyone know a quick fix until then?
Thanks
Thanks
