What i did was use the "high mileage" freon with the oil that is supposed to have the oil built in there. Didn't rattle before I did that BTW.
92 DX A/C compressor rattles at idle only
93 EGT 5M, Bimini Blue
132k miles, DD only
0w20, EG Fram Oil Filter for Probe 2.5L, Magnetic Drain Plug, ebay cone filter, 03 Protege Rotors, moog sway bar end-links on rear sway bar, mx3 seats, Power Sunroof, Miata Valve Cover Bolts, Gatorback Belts, Timing *14 on 87 Oct, Autolite 3924 @ .043 - 35 mpg at 67 mph (95% highway driving) with A/C and headlights on. Untested for fuel economy: Sylvania EcoBright 9004, .717 5th gear with D6 ATF, NGK wires, 195/65/15 Kumho LRR 4 wire tps
Former Car: 92 Protege DX 5 spd.
Originally posted by ProjectProtegeMine does the same but mine clicks real fast when im idling with no cold air but when i rev it up to 2 ro 3 its goes away... Im thinkin the compressor is goin bad... goin to by a new one
Let me know if it was the compressor when ur done bud, how much is a new compressor btw?93 EGT 5M, Bimini Blue
132k miles, DD only
when you say the compressor has oil, was it oiled prior to charging and then again after it was charged. youve got 2 types of oil you need PAG and ESTER. you may just need a pag charge theres 3 different types 70, 100, and the other is 140 i think, get the 100viscosity and charge it that should take care of it. If the comp was killing itself it would be throughout all rpms. also you may just have a "dirty" compressor. **** builds up inside and restricts oil flow inside the comp letting less oil in under lower pressure(i.e. lower rpms). parts stores sell ac system flush/clean kits over the counter.
mine does the same thing
but my compressor has been making this noise for about a year now.... i use the ac heavily (i live in miami). i talked to someona at ford and they said that it could be the ac clutch. because the compressor works fine just "complains at idle" other symptoms incluse odd idling while coming to a stop the cars rpm will drop below 800 really quick and then come beck up like if i shut it off for a fraction of a second.....93 protege lx 190k, stick, girlie green
Originally posted by protouserbut my compressor has been making this noise for about a year now.... i use the ac heavily (i live in miami). i talked to someona at ford and they said that it could be the ac clutch. because the compressor works fine just "complains at idle" other symptoms incluse odd idling while coming to a stop the cars rpm will drop below 800 really quick and then come beck up like if i shut it off for a fraction of a second.....Ratrod
Originally posted by JoeC254when you say the compressor has oil, was it oiled prior to charging and then again after it was charged. youve got 2 types of oil you need PAG and ESTER. you may just need a pag charge theres 3 different types 70, 100, and the other is 140 i think, get the 100viscosity and charge it that should take care of it. If the comp was killing itself it would be throughout all rpms. also you may just have a "dirty" compressor. **** builds up inside and restricts oil flow inside the comp letting less oil in under lower pressure(i.e. lower rpms). parts stores sell ac system flush/clean kits over the counter.Ratrod
most of the cleaner kits you just charge into the system like you would freon, you need to take some out first. find a shop with an AC system recovery machine(big ass vacuum). they'll take out the freon and store it, clean the system, and then recharge it with your freon. SHOP AROUND, ac service prices vary a lot so dont get raped by some backyard mechanic and his fancy new toy.
Good thread, model specific information on AC is pretty difficult to find.
Thanks93 EGT 5M, Bimini Blue
132k miles, DD only
could you not add a small amount of oil to your existing freon as a quick diagnosis to see if the problem goes away?93 EGT 5M, Bimini Blue
132k miles, DD only
