I believe its similar to the BG chassis like the MX-3 (EC) is as well. As in you'd need to swap one or 2 mounts, but for the most part its pretty straight forward.
Ok, i was curious, cuz the link was for the BF chassis swap,what is the drive train setup pf the 323F? thats the main desiding factor
Its in the title. 1.6 16v motor. I would assume its the same as the DOHC B6 found in late model MX-3 RS's.... making the swap oh so similar to the B6t ~>BPT conversion
As stated above, the 323F has nothing in common with a BF chasis, nor does it come with a B6T. There are no mounts that need to be changed, they are all standard the same as the BPT. Only thing you have to change is the fuel pump wire from the GTX loom into the 323F loom. You also may have to modify your radiator fan a little.
BG Astina + GTR convertion + Microtech ECU + FMIC + 3" Exhaust x 21psi boost = 12.168sec to the power of 326whp
Here's My Worklog and My YouTube Videos
No not really, the B6 engine found in the BF chasis is quite different not only in mounts, to that found in the BG chasis.
