OK So I was at the wreckers today and was looking for a TB for my 91 323 SOHC 8 Valve engine! well I decided to take a look at the 16V SOHC engine and I noticed that the TB inlet was bigger! So I removed bothe of them and put the 16V on the 8V and it bolts up fine and the flap doesnt hit! does anyone know if this will make a difference in performance bny using the bigger TB and if it will work??
TB swapping?? 8V to 16V?
The flap moves without hitting anything? I always figured you would have to dremel/grind out the intake manifold port to allow more air through to make up for the more air the tb is letting though...but i guess if the flap is still good at full throttle you wont have to drill anything out.
Performance wise im guessing if you adjust the idle correctly you should at least gain a LITTLE more hp. especially with that weak of an engine.1991 Mazda protege DX (SOHC) 5spd
Short ram cold air
stock muffler back on
NGK plugs
14inch miata steelies w/toyo proxes p185/60r14 82H - back
13inch protege steelies w/toyo proxes S rated - front
stripped a/c
1993 saab 9000cse turbo 5/spd
Garrett TB-25, solenoid cut off at 17psi
Gutted cat w/borla muffler
Aero spec clutch (7k miles old)
Running 5w20 full synthetic...(241,***)
16inch Aero rims
Aero Moldings
Bridgestone Potenza 205/55VR16 91V - all 4
wow, maybe you should read my damn tb FAQ on my site >:O
it says the b6 is 50mm and the b8 is 55mm.
some bp's are 55 some are 60..60's being harder to find93' Noble Green MX-ZE (sold)
OWNED by the Accounts Receivable department!My ClubProtege.com Feedback Thread
MOSI Race Dynamics - Aftermarket Parts Sales & Services MOSI Race Dynamics Feedback Thread
actually dave was hosting the site on the old protegeclub server.
the site will be up on this server soon enough
either way the faq is on this forum too..& searchable >:O93' Noble Green MX-ZE (sold)
teh search came thru
