i recently did the N/A BP swap into my mx3, everything is working flawless and the motor runs great.
the only problem is that i can only get luke warn air when the gauge is hot.
ive replaced the thermostat, and it didnt fix it.
now when i was in the middle of the swap i accidently snapped off the fan switch, the one with the grey connector that goes into the thermostat housing. so i replaced it with the stock one from the 1.6L
will that cause my problem? or did i get a "Summer" thermostat?
and i did run the air out of the system when the engine was put in.
