Hey guys,
First off YES I have done plenty of searching through the forum and have yet to come up with the info that I need.
Ok, I plan on doing the 2nd gen GTX swap into my 323 at the end of the winter, but I 'am getting all the required info that I need now so that I don't run into problems.
I just purchased the Engine from J-spec Auto sports in Quebec, Canada, comes with the Engine, ECU, and the wiring harness.
Last winter I did an auto to manual swap, because of the obvious I don't like automatic. So I still have the automatic ECU and wiring harness and all the electronic goodies that went on an automatic engine (TPS, etc). All I did was jump a few wires.
So now I outgrew the B6E so In goes the BPT. One problem?
J-spec Auto Sports callled me today and said that they are having a problem getting the wiring harness and said that they would give me a $200.00 usd discount if I didn't bother with it.
Is it still possible to use the B6E automatic wiring harness with the GTX ECU?
What about the connectors (Knock sensor, TPS, O2 sensor)?
I checked my stock ECU and it has 3 yellow connectors going into the ECU on the passenger side and my TPS is a 4 wire if this helps with anything
If anyone would be able to help me out it would be greatly appreaciated.
Thanks, Steve
P.S. Anyone have or know where i can get a wiring diagram for the GTX.
Thanks, Steve
