ok, so im searching around looking for stuff for my car, and i stumble upon this, if im correct(and i usually assume i'm not) but didnt the 88-89 323 GTX utilize the b6 engine? so with some kind of modification, would this exhaust perhaps work on our cars?
Exhaust Question
For that price, you might as well get a custom exhaust done.-------------------------
'91 LX
'03 Mazdaspeed Protege #235
Originally posted by 323driftok, i didnt want to start a new topic so i decided i'd just add into this one, i was poking around the toda racing website and realized that they had quite a few products listed for the B6 engine, will any of these products work with the B6 out of a 323?-------------------------
'91 LX
stock B6 in a 323 - depends on the part.
The SOHC motor in the 323 is an econo motor, and those TODA products are for the DOHC B6 in the 90-93 miatas and in the 94/95 MX-3's. Probably works in the B6 in the old BF's, but I couldn't tell you for sure.
You could always swap to a DOHC b6, but most will just swap for the BP and enjoy the extra displacement.
