Protege on 13´s rims...and proxes RA1
    I live in Panamá (Central America) i have an LX 92 without cat conv. 2 1/4 exhaust system and RX7 VAF, timming at 18 degrees. and thats pretty all..when i run my proto, i feel that the slow gears of the car are First and second, but third gear is the strong one. what i am planing to do! i will use proxes RA1 tires threadwear 40 but on 13's rims...this will shorten the grear ratio and will make the third gear come faster...than if i use 14 inch wheels or 15!...both Proxes Ra1.
    Thats my idea any coments about it? i am on budget, so if there is any help about "settings" used in a Nearly Stock car.. will be helpfull.
    I have a Drag Race, these weekend.
    94 lx, custom manifold Mitsubishi 16g (EVO III) turbo, XTD stage 3 clutch kit, strut bar, and 3 inches exhaust free flow. Natural aspired Head and Block, RX7 N/A 440 cc injectors, GTX intake manifold, MS2 V3 (stratifiedauto) , SX Fuel pressure regulator, Front mount intercooler, TD05 16g turbo
    It'll help a lot. RA1s have a lot of grip. But the RA1s really like heat, so do a big burnout.
    "Never run out of real estate, traction & ideas at the same time"
    -93 MR2, 129 ES
    ClubProtege.com Tech Articles
    Originally posted by WTF
    Remember low compression makes more space for AIR, HEEELLOOOO!
      I thought that the LX's had the 22V 14 calipers, which required a 14" rim? Or, I could just be displaying my ignorance again... Otherwise, I'd be throwing some 13x9's on my wagon and having a blast.....
      --sarge
        yeah i coudlnt fit the 13s on my old lx.... 3rd gear?? i always felt mine as 2nd..
          --sarge
          You could probably find a 13" rim with an offset that would clear the calipers. I doubt the factory steelies would clear, but perhaps an after market wheel. For ****s and giggles I can try to put on my 13" steel wheels after I do the brake swap.
          2005 Mazda 3
            the steel wheels i already tried it... took the steelies off my 323 and tried putting them on my protege when i had it .. dindt work
              There are 13" wheels that will fit over the brakes. Keizers for example will fit. Joe Graves used to run them on his FSP Escort back a few years ago with great success.
              -93 MR2, 129 ES
                Thanks for the advise!
