Well i was changing the thermostant on my bp05 and SNAP the fan switch wire just complety broke and i was like "damn might as well bypass it" but there is one problem i don't kno how to bypass a fan. I was hopping u guy could help me out???
Fan Bypass
Fan Bypass
My Vouch Tread:http://www.wihandyman.com/forum/showthread.php?t=25276
My myspace:
http://www.myspace.com/haitianstreetracerTags: None
ok, well here's what i did, they'll be a wire that goes to the coolant probe/sensor that plugs into your thermostat housing, you can splice/cut that wire and then direct it to a positive power source and it will turn your fan on, i wired mine to the headlights and it worked just fine for me, drove that way for a good month
hope this helped
JACK-Jack
Originally posted by Mazda_Poweredok, well here's what i did, they'll be a wire that goes to the coolant probe/sensor that plugs into your thermostat housing, you can splice/cut that wire and then direct it to a positive power source and it will turn your fan on, i wired mine to the headlights and it worked just fine for me, drove that way for a good month
hope this helped
JACK
See mine broke at the top of the senor. Is there anyway that i cut the wire on the fan and connect it a positive power source???My Vouch Tread:http://www.wihandyman.com/forum/showthread.php?t=25276
My myspace:
so you're saying the wire broke off from the cooland probe/sensor?? then bring that wire to a positive feed and you're good to go, then just go to the wreckers when you have the time and get the female end of the probe/sensor plug
JACK-Jack
Originally posted by HaitianProtegeSee mine broke at the top of the senor. Is there anyway that i cut the wire on the fan and connect it a positive power source???
I had the same problem. I took the connector apart and redid the connection and put it all back together.
Originally posted by Mazda_Poweredso you're saying the wire broke off from the cooland probe/sensor?? then bring that wire to a positive feed and you're good to go, then just go to the wreckers when you have the time and get the female end of the probe/sensor plug
JACKMy Vouch Tread:http://www.wihandyman.com/forum/showthread.php?t=25276
My myspace:
