fastest bp?
    ive read alot about gtx computer talk, swapping them in and all... is it a plug and play swap or would i have to go harness hacking? obviously i would have to redo my exhaust. and motor mounts while im at it.
    93 protege lx 190k, stick, girlie green
      gtx with bolt on's is easy 200whp. i did it to the tune of 209whp @ 15psi.
      NEUMAN
        I am running a 13.880@98.24 60 foot 1.908 on slicks mounted on stock protege rims. I have 2 1/2 exhaust, mx3 cold air intake, pulley 80 shot nos.
        94 LX
        Mods: ebay mx3 cold air, rx7 air flow meter, NOS 70 shot dry, UR pulley, 2 1/2 exhaust, autozone clutch, which is starting to slip, slicks, motor mount inserts, cut pacesetter shifter, zx2 ploy control arm bushing
        no2 13.8 98 mph 1.9 60ft
          If you get the GTX ecu and GTX LHD wiring harness, it should be plug and play.
          There's a lot of good info in the Engine and Drivetrain Swaps section.
            Not bad!!! I was thinking of running some N20.....I already pulled off a 14.9, wonder if I could get in the 13.5s with an 80 shot?
            Eat ****.
