If i can get some adjustable cam gears for around $150 is it worth it? i have 10.5:1 compression pistons and will be getting the block overboard and dipped / p&p / kinfe edge and balance crank and rods .. and a few other stuff and hopefull a small quick spool turbo... so with all this will the cam gears give me much? or would my money be better spent on other stuff?
cam gears worth it?
cam gears worth it?
In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
The ProjectMx build thread
MyCardomain[/SIZE]
"Shut up, at least the bunnies are on fire!"Tags: None
well i was hoping to eventually do some kind of cam work...In the Garage
Black 93 MX-3 GS
Bp powered
GTR Drive Train
MyCardomain[/SIZE]
The cam gears are worth it if you shave the cylinder head and install some good exhaust like headers. Power increase is not given by just playing with them. What happens is when shaving the head or changing pistons the compression changes. The same thing happens when porting the head or doing some surgery on the intake manifold the cam gears will work. All the cam gears do is "CONTROL" when air gets in and out and how much time its going to be in your cylinder head. In all motor applications is good to achieve a vacuum effect opposed to force induction.
