ok guys i finally decide to do an enigine swap on the protege got tire of the sohc power. help me out on this one i will be dropping in the bp engine with the sohc transmission. which flywheel and clutch do i need to use. i also be getting th bp hardness,engine mounts, ecu and the vaf if am missing anything please tell.
help before engine swap
since you need a VAF to start, try grabbing the RX-7 B code while your at it. the BP will idle and runn on the SOHC VAF so that you can troubleshoot your swap if needed, then throw the b-code on, tune it and reap the benifits"Discontent is the first necessity of progress."
