Differences between the BP in the pro lx and sephia?
    apparently in my area, there are a few low mile bps available, from sephias. i was wondering if there was anything different about them compared to the bp that comes in the lx. if you know something, please lmk. the motors im looking at have 79k-85k miles on them, and the only protege lx one has 110k on it.
    obd2 on the newer ones?
      i believe the lx has a bp-ze, while the sephia's have a bp-de. the bp-ze has more aggressive cam angles, and probably a few other minor diffs. along with what ^^ he said.
      ---prakash
        both of them are 94s, obd1. so essentially it would be the same thing? i just need the car to run for now, so i can use it as a daily beater. most of the stuff i was gonna do to it was suspension wise anyways.
          PM Spenone If i remeber he's running a kia BP
            according to consumer guide, the 1994 kia only had a 1.6, the 1.8s weren't introduced until 1995 which would make them OBD2 unless the were produced in the first half of the year.
            Seth
            2010 Mazda3 i Touring
              kia bp's are all obd2.
              Almost there
              jdm tails... check
              jdm bumper... check
              ms lip... check
              ms grill... check
              ms sideskirts... check
              ms rear skirts... check
              ms spoiler... check
              ms struts... check
              Still trying for a bp swap..:
