is rebuilding a 5spd transmission hard? or is this something i just shouldn't attempt myself?
transmission rebuild?
It all depends on how experienced you are, how mechanically inclined you are, what tools you have, ect.
There are a lot of things going on inside of a transmission. If this is something you have never attempted before, I would get someone who knows what they're doing to help you, or at the very least, get a good manual to guide you through the entire process.
Originally posted by smoke187ok then i will just stick to the easy stuff for now,
kind of not sure if i should buy a gtx next summer with how hard it is to find a transmission where i live
What exaclty is wrong with your current transmission?
Originally posted by smoke187i found a transmission just going to get one from a scrap yard 145miles away 50k on it $275+80 to my door.
the $80 saves me 5 1/2 hr drive-Mike
06 Taurus SEL/92 Escort GT/93 RX7 R1
i should have the trans by tuesday i have to wait for them to pull it out of the car and check it over it has 50315 miles on it so they are giving me a 60 day-w.
im going to do just that take it apart i have a 6ftx3ft workbench that should be big enuf the trans still works kinda but only if you can jam it in gear, im also going to remove my es mounts untill i get a gtx or get my shifter fixed floppy shifter i have a shortshifter and bronze oil bushings.
