Ok, so last night I went to hook a switch up the the revers light switch because the wiring to the switch on the tranny is bad. So I wire it up to the connector (Two spades into the connector. Well, I turn the car on and no cluster lights. So I check and the meter fuse is blown. So I replace it, and I have all the lights except for the CEL and my SAFCII won't power up (come off of ECU power). So I look under the hood and replace the fuel injector relay fuse. Still nothing. So I parked it at my freinds. COuple things:
The car cranks over, so the main fuse under the hood is still good right?
All the cluster lights come on except CEL (Check Engine Light).
I havn't checked for spark and I don't know if I have fuel.
I don't know how the switch could of blown the fuse. Any help is appriciated.
