well i found out the coil problems were due to a bad condensor, so its fine now. but i'm having issues with fuel now it'll run for a couple seconds with some quick start, so i know its fuel. the pump doenst seem to be coming on, so i put some power to it from where the 15a fuse is and it started humming like a champ. and the both relays under the hood are fine, and i replaced them just incase with working ones from my protege. but the pump doenst want to come on with the car...any ideas guys? i know the pump works now, and the relays are good. i might have a FPR code...but the thing i dont get is the FPR is vaccum operated so how would you get a code? from bad vaccum?
anyways, any help would be a step in the right direction
its a 92 EGT.
JACK
its a 92 EGT.
JACK
