lower rad hose
    lower rad hose
    anyone mind tewlling me how to get the hose off, got the rad end off the the other i cant, its got hose clamps that just squeeze, i cant get pliers in there and screw drivers arent working.
    Eat the Insane Root.
    maybe i have to take somethign else out to do it?
      It's all about the angle of the dangle.
      I use these pliers for spring hose clamps, and they work pisser:
        When I tried to get my hose clamps off to change the radiator it had the same clamps. No matter what tool I used I couldn't get the clamp to open enough. So instead of clamping them like your supposed to I took two vise grips 1 on each little ear and spread them apart , worked like a charm. And then of course there is the dremel route.
