disconnecting the battery while running is a very bad idea. i've got a term for ya, it's called "power spike". it can fry your ECU or other electronics in your car.
What could be wrong with my car?
Create your own VB Gallery here.
Only reason I did that was cause I was told that it was an easy way to test it. I did take it to one of those places and got it tested and they told me that the battery was fine, and that the alternator wasnt charging. That was the first time I replaced it. The second time I installed the alternator and we disconnected the battery completely and it stayed running for a bit, but then it died again. The car will stay running as long as the battery has juice. But after a while my charge light comes on and it starts to die out. I am tempted to just take it to the Mazda dealership that it was bought from and have them at least diagnose it. Just want the thing to be fixed. It is frustrating having a perfectly good low mileage car just sitting and collecting dust.94 Protege DX... A work in progress.
Spring Tech Springs
Cross Drilled and Slotted Rotors
Cone Filter
17" Rotas
More to Come......
Originally posted by JhoThe first time you said that you determined that the battery was not charging by using a voltmeter or some sort of device.
Have you tried testing it again?
I have not tested it again yet. I am gonna take it to a local shop and have it tested before I take it out to the dealership.94 Protege DX... A work in progress.
Spring Tech Springs
Cone Filter
17" Rotas
More to Come......
Make sure you check the harmonic balancer. My kid's g/f has a '93 DX, and it wouldn't hold a charge even after the battery and alt. were replaced. I finally got a chance to look at it and saw a fine black powder all over the front of the engine. Got it started and the damn pulleys not turning. The rubber had come apart. $10 and a trip to Pick n pull fixed that.Current-'08 MZ3 Hatch auto, '04 MZ3 Hatch 5-spd, '03 Pro-Lx 5 spd,
'56 VW Cal Ragtop
www.cardomain.com/ride/2285117/1
normally when the light comes on it is not the battery but rather the alternator. you may have a wire issue. if you had the system tested by a machine that places a load on the system it should just give you a general good or bad on the charging system. i would have the system checked with the new alternator.
