Alluminium radiators?
    Can I get a link/links to any website/s that sell 100% aluminium radiators for our cars? After doing a compression test I found out my radiator is shot from the inside. And I need it ASAP. Help anyone? The way I'm driving it, it won't be long until the rad's down to scrap.
    Please people, this is an emergency.
      I've never heard of an all aluminum radiator made specifically for our cars.
      Your best bet would be a universal one like mine:
      Griffin Thermal Products Radiator Manufacturer, Aluminum Radiator, Custom Radiators, Heavy Duty Rad, Performance, Off Road, Industrial, Muscle Car, Street Rod, Radiator
        http://www.griffinrad.com
        That's a great looking rad. But I drive an auto, so I'd need it to have the tranny cooling lines on the bottom part.
          Something that just hit me, is that the mazda rads have plastic on the top and bottom, while the escort has it on the sides only. Is there any way to mix these two into one rad?
            If you wanted to use a radiator like mine, you could just use and auxillary tranny cooler.
            Why not just get an Escort radiator?
              because I'm trying to get an aluminium rad if possible, not an OEM replacement.
                Then get a griffin and use an aux cooler.
                  For that griffin I'd need a lot of modding to get rad supports. It requires skills and time I don't have.
                    Then get an OEM !
                      There is not one out there that will fit your needs without modding it. Get a new OEM one or make one yourself/mod one to work.
                      BP-05 Turbo-Sold
                      2004 MK4 AWP Jetta GLI
                        What he said.
                          not all pro rad's were plastic endtanks... the metal "dual core" radiator is sweetness, holds more fluid as well.
                            I purchased an all metal 2 core it's made by CSF and I bought it online. Not aluminum and they have been dicontinued so what ever stock is left is all they have.
                            2005 Mazda 3
                              http://www.radiatorexpress.com/produ...aia_id=1191855
                              ...well this is just great. I get this useful info right when I allready purchased and installed a new OEM radiator.
