i dont know of a reliable source, i dont want to use ebay, could someone give me a site they got theirs at and are happy with. i have a 93 Pro lx
Cai
1) there are none outside ebay for a reasonable price
2) I suggest you DIY and built one
3) keep the "H" box
if you to a quick search you will see that about 2 years ago i built a how to/need to know.
This is what i can remember from the post
-and the optimum size of piping is 2 3/4" - 2 1/2"
-the angles for the piping are ~78 and ~55 degrees
-if you relocate/remove the Coolant Overflow you have a nice well for cold air.
-Keep the H box
-Use a 3" dia 3"-5" radius bent pipe to go from the maf to the cone filter.
The little tube that connect under the throttle body to the H box is the idle bypass, you HAVE to keep it,
-the H box aids torque.
-post losts of Pictures\
-have fun while you DIYLast edited by Protoss; 07-29-2006, 07:57 AM.When you turn your car on... does it return the favor?
A Protege driver named Brock
So his engine he goosed
With much too much boost,
Stay away from the ebay SRI with the 90 degree bend in it. Parts missing as there is no way to hook up the hose from the h-box. But there is this huge lovely hole that has to be blocked off before use.c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
Originally posted by JhoThat and it's just a stupid design.c+p>c<c+d1>c+p<m+d2>m<m+f>f<c+p>m<m+f>f<f+s1>c+p<c +s2>c<c+p>
